2012 Chevy Volt 166,760 miles
I have tried my best to try to figure things out on my own but I I'm just stuck.
So let's start here, acouple months ago started hearing a clicking noise coming from the driver side front tire that sounds like a roller coaster. Come to find out the CV axle is bad. Call AutoZone ordered the part had the part picked up same-day $109. Call around to local garages in my town of Kokomo, Indiana to get to a place called Dad's garage. They say no big deal we can get it done Bing Bang Boom. Almost a week later, I Drop the car off at 9 in the morning they were calling by 10 stating that my passenger CV axle is also bad and needed replaced. I asked them what that was going to cost me they wanted me to pay 165 for the part. And then 145x2 for labor! I said no thank you I'll order the part myself.
Now, ever since they replaced the cv axle...i drove a half a block and lost acceleration. The ABS, TRACTION CONTROL AND ENGINE LIGHT, all came on! I called, took it back, they admitted that it was the first Volt they ever touched, but all vehicles are standard 😒they jacked it up, cleared the codes, and even drove it. Came back and said it should be fine! Later that night exact same thing happened. So my dash is still lit like a Xmas tree! I found out it is the front left wheel speed sensor that is making these codes show up. But Dad's Garage says it all looks fine. But clearly something Is wrong.
Been having issues with psi in tires. So, I took it to Discount Tire, where the tires were from. They checked it out? Said the front tires were shot I needed new ones. Luckily I had two tires already. They are 215/60/R17. But they work. So they take the no-good ones off. The back get moved to the front and the new on the back. Wake up the next day with a psi of 18! Took it.back, come to find out, it's the rim! So they tell me that I need to order new wheels. But I'm trying to just find one for the messed up one.
Also, I have NO heat. IF and only IF I can get it to switch to mountain mode, I get some heat. BUT, the car won't switch to mountain mode until the charge is depleted. I can push the drive mode button and it shows it switching, but it stays in EV mode. IF I pop the hood it does go to mountain mode though! I live in Indiana one day it's 75 and sunny and the next it's 25 and snowing. I NEED HEAT!!! SIDE NOTE- I did change the blower motor a few months back. There is plenty of air flow. Just really really cold air!
Also! 3 times now, within 4 or so months, I get up, take my daughter to school, go back home (maybe.4 blocks) get my son ready, go to the car and it's COMPLETELY dead. No welcome sounds, lights, can't pop the trunk...nothing
So I get my jumper box, barely touch the 12v and the entire car starts! Then of course everything is reset. But it runs fine for a while. The 12v battery is around 2 years old. Is something drawing power from the 12v? What could possibly just randomly do that? .
I am just at my wits end with it all. Nobody near me knows anything about the Volts, so they say. Everyone says take it to dealer. Well j don't have dealer money to get it looked at!
Any help or advice is appreciated! Thank you!
3 VEHICLE MESSAGES
1. SERVICE AIRBAG (I believe sensor under passenger seat issue)
2.SERVICE STABILITRAK
3. SERVICE BRAKE ASSIST
ENGINE LIGHT ON
TRACTION CONTROL LIGHT ON
ABS LIGHT ON
3 VEHICLE MESSAGES
ENGINE LIGHT ON
ABS LIGHT ON
