During a road trip, I decided to see what would happen if I drove my Gen2 (2017) Volt in hold mode until the gasoline ran out (while having plenty of battery power--i.e. 4 out of 10 bars--available). My expectation was that the car would detect extremely low gasoline levels and automatically switch to fully electric propulsion. That's not precisely what happened.
When the gasoline engine shut off, it made a bit of a thump, my best assessment is that it literally ran down to fumes. I don't think I damaged anything doing this once, but it's not something I would intentionally do again.
The car seamlessly switched to full electrical power, but I got a reduced propulsion power warning and the car would only limp along at about 60 mph, despite there being plenty of battery power. My guess is that the engineers' logic is that if gas was fully depleted, electrical power should be rationed to maximize the range available to be able to get to a gas station.
At the same time, I'm guessing that if you fully depleted the gas, and shut off the vehicle, and turned it back on, it would then run normally in electric-only normal mode as long as you had sufficient battery power. Can anyone confirm?
When I stopped at a gas station to refuel, everything was back to normal operation again.
