Hello, fellow Volt-lovers!
Ever since I took my Volt in for the battery enhancement over Memorial Day weekend, I've noticed a couple odd problems, and I'm wondering if they are related (to each other and to the upgrade).
Before the upgrade, my steering was commandingly smooth at all speeds and turn angles. Now, I feel more communication between the road and the wheel -- but what bothers me is that at low speeds, and especially when turning to the right, I feel what I can only describe as a rough spot. This happens about a quarter-turn to the right, and with just a little bit more force I can overcome it, but the feel is very non-linear compared to just before and after this point in turning the wheel.
Also, like everyone else, I could always feel a difference in the resistance on the brake pedal at the edge between regen and hydraulic braking, but now there is a spring-like feel that is more noticeable, and the pedal is more... mushy?
I'm not 100% certain that the battery upgrade process caused these issues, because they would seem to be unrelated. Do they break into the power steering / braking hydraulics system for that upgrade? Could something like air in the system cause these symptoms, or would it be a physical obstruction?
I plan to schedule an appointment with the dealer as soon as I can, but I just wanted to put my experience out there and see if anybody has ideas or had a similar situation. A search on the forums found me a few posts on total loss of power steering, and a strut issue that causes clunking, but neither seems to describe this particular issue. I had OnStar perform a diagnostics with no findings, and I spoke with a Volt Advisor, but she hadn't heard of this issue either.
Luckily, it doesn't seem to really affect my ability to drive (at least not yet), but it does decrease my fun with the feel of driving this amazing machine -- by just a little bit.
Your inputs are most appreciated!
