Here is a summary of my findings. In addition, it appears it sits between the charging port and the on board battery charger for the pilot wire connection.
(Located under the front passenger seat)
The hybrid powertrain control module 2 has many functions:
monitoring the hood latch
sends the bcm a signal to honk horn during plug in
charge door/fuel door functions
fuel tank pressure before filling
sends pwm signals to cooling fans (pass through from ecm)
gathers reading from ambient air temperature sensor
controls a/c compressor speed based on other sensor inputs (like battery temp)
controls passenger heater core valve
controls high-voltage contactor relays
controls 14 v power module vent fan
battery pack coolant pump
receives faults from on board battery charger
calculates battery performance
works with battery charger for cell balancing
modifies the control pilot signal
time of day charging feature
monitors input/output of on board charger
evse cable attached check (proximity detection)
