How long can the 12 volt AGM battery last in the Volt?
1 reading
15K views 27 replies 18 participants last post by  jayoldschool
#1 ·
My early 2011 Volt with over 100K miles, still has the original 12 Volt battery and it can still supply more than 20 amps for more than one hour.
I cycle the battery about every 6 months to keep dendrites from shorting out the cells.
#2 ·
You are brave. Several threads on this. I'd replace it ASAP. Our 2011's died all of a sudden. Replaced the other kids a few weeks later.
#7 ·
I live in Michigan so the heat is not a problem.
I just tested the battery yesterday and it is good.
I am well aware that lead acid batteries normally do not give much waring before failing, however I have tested thousands of batteries and if you know what to look for during a full cycle test, with this knowledge I can get at least 3 months of warning. The key to this is looking for how sharp and where the knee is in the discharge curve, in a full cycle curve.
Quick battery testers of any type, can't give this kind of warning.
#8 ·
I replaced my battery about 4/5 months after first indication of a problem (compass disappeared). I happened to have the cargo cover up (can't remember why) and happened to measure voltage (11.9V). Never had any other problems but Canadian Tire was having a pre Xmas sale plus a $50 card promotion so bought the battery and returned the old one for a core charge. I don't need the compass (I know which direction I'm headed) but it was 6 years old, I typically get 7 years out of a lead acid on my other cars, so wasn't worth waiting till I needed it most. Temps here are the best you can get for a battery (not too warm and not too cold). A battery can have a wide range of life depending on a variety of factors not the least of which is the manufacturing of that particular unit. If it's getting on and you notice something off, replace it while you can, especially if a good deal is out there, waiting to be had.
#11 ·
Aside: Here is a drop that happened in my Tesla X a few days ago. AGM deep-cycle lead-acid.
#14 ·
In my opinion, you're flirting with an event that could ruin your day and be expensive to resolve.
In lieu of complete AGM replacement, you should have some sort of means to power the 12V systems back up should the AGM just instantaneously die on you. I have been contemplating carrying one of my copious 18V powertool batteries with a buckpuck (they're 10$...) outputting 13V around with me to essentially jump the car via the connectors in the engine bay, should it be required.
This car just needs a couple Volts to start up whereas most other vehicles need the Amps to start. If you have ever seen a Volt with a dead 12V, it's nothing like most other cars; when my MY12 died on me about 6 months ago, it was super dead, like no indication or lights at all. Then there is also the aspect that happens when the computer's reference voltage drops too low during operation. The car literally died during operation. That was baffling to try to resolve but it turns out when I had installed the new AGM, I had a poor connection on the battery and it worked itself loose.
#17 ·
I did some googling for an AGM 12V battery, and one of the sites that popped up was Batteries Plus Bulbs. The price of the battery was $140 less a 10% discount and plus a $12 core charge. 'Not sure where I picked up the 10% discount code. I'm still looking for someone's discarded battery to recover the $12.
#19 ·
I bought a Duracell AGM battery from Sam's Club. The regular price is $145 but they often put it on sale for $125, plus a core charge. It is exactly identical to the ACDelco OEM battery it replaced.
  • Like
Reactions: allen42b
#20 ·
I would run my computer UPS with my old Volt 12 v battery BUT by the time I have 2 batteries ( UPS uses 24 volts ) my first battery would be 14 years old :)
point is we are not testing our replaced battery that are removed for a just in case condition.
batteries plus may give a 10 % on internet orders with a self pickup -
#21 ·
Changed the 12V in my 2013 Volt from the dealership two days ago. Original 12V lasted almost 8 years. Cost of battery $189 without tax from Findlay Chevrolet. $40 to install. Took them 2.5 hours to finally install it.
#27 ·
I think you may have the record
something something chicken dinner :)
I chickened out when I saw 11.9 volt on a winter day while applying the parking brakes
still on my second batery.
