Do public chargers, such as Blink, stop charging when your battery is full?
16K views 17 replies 14 participants last post by  Dairine2003
#1 ·
Let's say you are using a public charger, and it takes 4 hours to fully charge your car.
At that time, do the chargers turn off and stop charging both your car and your wallet?
Or do they continue to trickle charge and will charge you for as long as it is connected to your car?
#2 ·
They stop charging your battery, but they may or may not stop charging you depending on their rate structure. (i.e. per hour, or per kWh).
#4 ·
The EVSE (Electric Vehicle Supply Equipment) doesn't "charge" the battery. Each EV has an onboard AC to DC converter and battery charger that monitors the pack voltage and temperature with built-in sensors until its limits have been reached. Then the charger tells the EVSE to stop the AC supply. In few words, the EVSE (public or home installed) is an intelligent "extensionn" that communicates with the EV onboard charger using the SAE J1772 standard to prevent harm to the vehicle or the owner.
The onboard charger is what determines if the pack need a "trickle charge", and may cycle the EVSE on and off to supply AC power as needed. The pack temperature versus ambient temperature management is one arrangement where the EVSE may indeed cycle on and off to maintain an established battery temperature using the EV's built-in heating or cooling systems, and you willl get charged for its supply while connected to the EVSE.
In the future, when we have larger packs, probably over 40 kWh, we will need fast DC chargers and those will have their intelligence offboard, not in the EV, but connected to the same sensors inside the EV pack, because that external charger bypasses the smaller onboard charger.
#5 ·
For those that charge, they charge while you are plugged in whether the car is charging or not. Some will charge for a full hour if you go x minutes over. Some will charge a much higher rate after say 4 hours (encouraging you to unplug before then and move on). Buyer beware. Read the fine print.
#13 ·
Just to be clear, for those that charge per hour that is true, but not the ones that charge per kWh.
#8 ·
Sounds like at a minimum I need to be there to unplug as soon as the charging is done.
That sounds like a good idea regardless of how much it will cost you. Other may want to use that charging station as well.
Just think of the children ;)
#10 ·
Ok, got my 'charge complete' e-mail from Blink.
At the bottom they say 'Hourly fees are charged until you disconnect..Fees are rounded to the next hour with a 2 minute grace period at the beginning of each new hour'.
So at least for Blink, you get charged as long as you are plugged in. And have a 2 minute window to save yourself from being charged another hour.
As a side note, I have my OnStar setup to let me know when charging is complete, and it hasn't worked for days now for some reason.
#11 ·
Volt owners are screwed by charging stations that charge you by time plugged in. Other EVs like the Nissan Leaf and Tesla, charge at twice the rate of the Volt, so the Volt owner pays twice as much per Kwh. If a Volt uses the station for four hours at $1.00 per hour, it will pay $4.00 to go 40 miles. That's 2.5 times the average cost of charging at home. You might as well just use the ICE in that situation. Stations that charge by Kwh are more fair but could still be more expensive than running on gas. Free charge stations are great but hard to find.
#17 ·
Most public EVSE's I run into are blocked by an SUV who parks in the spot... or is already in use. I seldom see one open. When I did try to use a Blink EVSE it cost more than gasoline! I just don't bother any more. I charge at home or I don't charge at all. Never trust em. And they are grossly over priced. I guess those who have a BEV are willing to pay for those outrageous rates so they can make it home. The Volt has no range issue... Cheaper to use the Volt's engine than any Blink EVSE I have run into.
#18 ·
I used a Chargepoint machine when I was in Las Vegas. As soon as the car was done charging, I received a text message saying that the car was drawing very little charge and was probably done charging. The charger was free so it didn't make a difference (I could see the charger from my room and I was the only car who used one of the two available spots all week!) but it did seem to imply that it would continue to pull some charge as long as it was plugged in. Being as hot as it was, it was nice to have it plugged in to use their electricity to keep cooling the battery. It was also nice to remote start it and get the cabin cool enough for my grandma to ride in comfortably.
