We get about 40 miles per charge. Cost of electricity is 28 cents per Kwh at Tier 4 and 34 cents at Tier 5. The Volt will put us into Tier 5 every single month.
We use the vehicle for commutation only. We leased it to access the car pool lane. Thats the only reason. That said - my wife likes the car alot. However - I'm assuming that gas goes back down to about $4 a gallon eventually out here - and 12Kwh at 34 cents is $.08 - so operating the Volt will cost about the same as buying gas.
We don't really worry about charging it that often since its being used for the car pool lane and we don't care if we use electricity or gasoline - the cost to us is the same.
If you use the car 5 days a week for the entire charge - as we do - there is NO way using the most common electric rates in big cities that you are going to save any money charging it instead of using gasoline.
60Kwh a week times 4.25 weeks in the average month is 255Kwh a month - thats alot of power - its 1/4 megawatt - you will be kicked into a higher billing level in almost every large city in the nation . . . . which will offset the savings you may get.
Where can you but 1/4 megawatt of power in our country for 10-14 cents a Kwh in ADDITION to your normal hotel load? Its not possible. Volts cost the same to operate as regular cars.
Edison has draconian rules for adding a new meter and accessing the 14cent / Kwh power - it would cost about $3k to do it - there is no savings over the 3 year lease of the vehicle. So there is no point in doing it right now - there may be different rules down the road - but - well - when you add the cost of the installation into the 3 year lease of the vehicle you come out right about 32 cents per Kwh - Edison knows what they are doing. They do not want to sell cheap power.
