21 - 40 of 40 Posts
It's exciting to read about the electrification of the pickup truck and other truck chassis vehicles. The possibility of an Escalade E-REV gets closer every day.
While conversions are an excellent way to improve the existing fleet of trucks, the manufacturers need to build them. Ford, GM and others could help their CAFE standards by building them on the assembly line.
Sorry for hijacking the thread, but I used to come on here quite often and wanted some of your all's thoughts. I live in the Bay area- where people are more likely to buy cars like the prius, Volt, and Leaf. I've been keenly interested in the Volt for years and would love to own one someday. That said... the 40k price has got me waiting until a cheaper version is hopefully available.
That brings me to the point I want to make. Around here I am seeing a LOT of Nissan Leafs. As in they're starting to become frequent enough to the point where they might as well be a Prius. They seem to be doing really well here even though in my opinion the car has got some serious shortcomings mainly in that if you run out of juice- oh well too bad and that its a car that would only be practical within the immediate area you live and not something you could use for long road trips. Even so- they seem to be selling well. On the other hand I have seriously only seen a handful of Volts. Half of those are owned by utility companies. I hardly ever see them on the roads around here and again- if there were anywhere that people would buy these- the bay area is one of the best bets. This is a disappointment. So what gives? Is it the price? Is it that its not all-electric? I can't figure it out. There's certainly no shortage of people with tons of money here.
fishhawk : That’s true, but it still means they have to pull the current from a 110v outlet. If the Volt charge cor takes 15amps, then to charge twice as fast means you are pulling up to 30amps from common outlet. I doubt there are many garages or outdoor outlets that can supply that much current. Peole are reporting problems just providing the current the 110v Voltech charge cord needs.
Seems like only a 240v outlet will work well.
The amount of current that flows in a circuit is limited by the cable size (like the size of a pipe for water). You can put a 60 amp circuit for 120 VAC (up to 7 KW), but most homes don't have that type of capacity as built. The home circuits must be modified or the special cabling added on, and it isn't worth the money.
Increasing the voltage (same as increasing the pressure) allows the same power to flow at a lesser current. This is why the Level 2 charger uses 240 VAC, so the battery charges at a higher rate (and takes less time).
If future home were designed to handle 480 VAC, then changing an EV can be done at a much higher rate and take much less time, as long as the charger and batteries can handle that voltage. Then we could charge a Chevy Volt in minutes.
edvard : Sorry for hijacking the thread, but I used to come on here quite often and wanted some of your all’s thoughts.
There have been fewer Volts made and sold and the Volt is being sold in more places. So for starters you have more Leafs concentrated in CA. By contrast, if you were in MI, where the Volt has been sold but the Leaf hasn't been, you wouldn't have the idea that the Leaf was selling well. Ditto for all the states where the Leaf isn't being sold, and that's virtually all states.
The other thing is that you have to think that the $5000 rebate for the Leaf made it more attractive. I think the Volt is a better car. Definitely worth a premium but $10K is probably stretching it unless you need an EREV. My guess is that with the Leaf rebate halved, the Volt in line for only a slightly lower rebate, and more Volt production we'll see a change in the numbers.
FWIW for the first few months of the year I saw more Volts than Leafs. Now I see more Leafs. But overall the difference isn't gigantic.
edvard :
Sorry for hijacking the thread, but I used to come on here quite often and wanted some of your all’s thoughts. I live in the Bay area- where people are more likely to buy cars like the prius, Volt, and Leaf. I’ve been keenly interested in the Volt for years and would love to own one someday. That said… the 40k price has got me waiting until a cheaper version is hopefully available.
That brings me to the point I want to make. Around here I am seeing a LOT of Nissan Leafs. As in they’re starting to become frequent enough to the point where they might as well be a Prius. They seem to be doing really well here even though in my opinion the car has got some serious shortcomings mainly in that if you run out of juice- oh well too bad and that its a car that would only be practical within the immediate area you live and not something you could use for long road trips. Even so- they seem to be selling well.On the other hand I have seriously only seen a handful of Volts. Half of those are owned by utility companies. I hardly ever see them on the roads around here and again- if there were anywhere that people would buy these- the bay area is one of the best bets. This is a disappointment. So what gives? Is it the price? Is it that its not all-electric? I can’t figure it out. There’s certainly no shortage of people with tons of money here.
It may be a case of how initial release areas overlap. The LEAF has been made available only in some "EV ready" locales, the Volt in only a few cities. Are you near the heart of a LEAF release area? Also, total numbers for the 2011 Volt were kept very small as GM tooled up for future EREV production.
The situation for the two makes is poised to drastically change for the 2012 model year; during which the Volt will go nationwide (or nearly so) by the end of this year or early next. Meanwhile, the LEAF will continue it's slow rollout to small "islands" of availability.
For many of the reasons you brought up, you cannot really judge a national trend by what you see in the Bay area. Most of us have never seen a LEAF on the road (and precious few Volts). While there may be a concentration of EV purists in San Francisco, I doubt this is as likely in other parts of the Country. My advice is to watch national sales figures once Volt availability expands, to get a clearer picture.
Jackson : Someone please give Don C a [+1] at #9 (I meant to vote his [-1] away, and clicked the wrong button, @!#$^%&. Sorry, Don).
#18
Don't feel like the Lone Ranger, LOL. +1 for fessing up, hahaha. I've done it several times over the months. Pretty irritating!
FWIW, he's at +1 now where you wanted him to be.
I'm thinking that GM is WAY ahead on this deal if they choose to be players. They already have a highly developed light truck hybrid system, which Ford and Chrysler do not. Plug a big battery in under the bed a la the PIP and go for it. They also have way more experience with EREV, REEV, or whatever anybody chooses to call it.
I have to think that 30 miles of AER is pretty optimistic given the weight of an F150 and the aerodynamics which approximate those of a brick IMHO.
Loboc : This is for fleet use. I’m sure adequate L2 and L3 capability is part of the decision to go this route.
Again, I was just saying the article says "ALTe says the A123 battery pack can be charged within eight hours from a 120-volt outlet..". That seems like too much current to L1 charge a 21.6kwh pack from an 120V outlet.
fishhawk : Again, I was just saying the article says “ALTe says the A123 battery pack can be charged within eight hours from a 120-volt outlet..”. That seems like too much current to L1 charge a 21.6kwh pack from an 120V outlet.
In a commercial setting, higher amperage is available at this voltage than is possible in a home service. Having said that, I would be very surprised if a commercial operation didn't avail itself of 240 - 480 volt charging. Copper is expensive.
"120-volt outlet" could be a typo, with 240 volts intended; but I'll reserve judgement for now.
Discussion starter · #30 ·
Jackson : “120-volt outlet” could be a typo, with 240 volts intended; but I’ll reserve judgement for now.
Not a typo. Originally the press release said "110" volts, but I changed it to 120 for consistency's sake, as this is the term I have used prior. Both 110 and 120 are referring to common U.S. household current which is in that range and gets called both depending on who's writing. The "about four hour" recharge time frame was for "220" volts, AKA 240.
Remember when we were speculating about what GM was going to use the A123 batteries for???
Well since in this article A123 is being used for a 20+ kwh pack , my guess is that GM is going w/ A123 for a pure EV!!!
That would be cool too.
So GM will have an EV and eassist then the Volt as ranges of options.
I just can't keep from wondering though if GM has any plans for the little 2 mode in a plug in version. They could do that too.
There was a good article in the WSJ yesterday about the new Malibu redesigned w/ low CD aero package and e-assist
http://online.wsj.com/article/SB10001424053111904332804576538473602208348.html?KEYWORDS=coaxing+miles+malibu
DonC : There have been fewer Volts made and sold and the Volt is being sold in more places. So for starters you have more Leafs concentrated in CA. By contrast, if you were in MI, where the Volt has been sold but the Leaf hasn’t been, you wouldn’t have the idea that the Leaf was selling well. Ditto for all the states where the Leaf isn’t being sold, and that’s virtually all states.
I'll add, you are more likely to see Leaf's in more mild climates. I don't think the Leafs will sell well in the extremes. Also, if you are in a die-hard EV market, a lot of the early enthusiasts will go for the pure BEV. Once the rest of the country catches up, you will see more purchases of the more practical Volt.
kdawg ,
Could you go to yesterdays article again I had another question on the Home button and the big display/ Nav feature I still don't understand
Thx,
GSB
Under California's new diesel laws, by 2022, any 2009 or older diesel truck that's more than one-ton, ie F450s, F550s, etc. (14000 lbs. GVWR or more), must replace its engine with a 2010 MY or newer (No matter if a 2010 Ford 6.4 tdi is the same as 09 or 08).
If you have an F450 to tow your 5th wheel or toy hauler, and it's paid for, how much better would it be to get a REEP than a same ol same ol 6.4 tdi diesel ? In 10 years there might be a lot of good rolling stock that could be given new life...
At_Liberty :
Under California’s new diesel laws, by 2022, any 2009 or older diesel truck that’s more than one-ton, ie F450s, F550s, etc. (14000 lbs. GVWR or more), must replace its engine with a 2010 MY or newer (No matter if a 2010 Ford 6.4 tdi is the same as 09 or 08).
If you have an F450 to tow your 5th wheel or toy hauler, and it’s paid for, how much better would it be to get a REEP than a same ol same ol 6.4 tdi diesel ?In 10 years there might be a lot of good rolling stock that could be given new life…
Whoa,
Now that's new to me (the diesel replacement law).
The original business plan was to retrofit fleet trucks and vans with 100k miles worn out engines.. replacing the engine with a GM 2L Ecotec 4 cyl (yes, in a Ford truck) and the serial drivetrain.. along with a new powertrain warranty. The new warranty was the big draw. Plus vastly reduced emissions and much better fuel economy.. all of these are attractive to large fleet operations. The upgrade to a rebuilt transmission increases the cost and is news. It may be cheaper to upgrade motor torque and get rid of the transmission altogether.
Will fleet operators bite?.. perhaps. The long term savings are substantial, plus grants, green requirements and tax benefits.
Randy :
Seems it could be done for a lot less than $30,000 ,cant see any value there for non fleet customers
A new BEV truck (if availalble) would start at $50k or higher.. I suspect many non-fleet customers would jump at the opportunity for a unique vehicle such as this. They may allow private customers to slip in a truck or two in the third party maintenance centers that will do these conversions. There are millions of F150 trucks in the US, and they all get around 11mpg :)
21 - 40 of 40 Posts
