21 - 31 of 30 Posts
Eco_Turbo ,
Well, how about a new standard-type of refillable canister? Give AC / Delco some more Simoleons. Seriously, a home BBQ tank is too big, but some new standard half size or smaller could be made refillable. With luck, it might be used to fuel some small portable grill for tailgating; and therefore be made available at every Home Depot and Wal-Mart. And maybe find a different place to attach it.
Remember, gasoline also has a "Ka-boom" factor, but we have the Volt.
Then again, I didn't specify GM; though it is possible that they either haven't thought of it, or won't take the idea seriously. Perhaps with good reason.
Nelson : In other words a regen paddle that works like the brake pedal?
I don’t think it’s necessary.
I think it would be OK, since in the Bolt, the brakes are friction brakes only (no blending). So if you want to avoid waste heat to brake pads, you could use the analog hand paddle for regenerative braking.
Kdawg : I think it would be OK, since in the Bolt, the brakes are friction brakes only (no blending).
Good Grief!! Why would that be? Now we're braking hand-and-foot -? -!
Kdawg ,
Didn't I read that Bolt has one foot driving, which I assume means max regen whenever you let off the accelerator? It said you can bring the car to a complete stop without using the brakes. Sounds interesting. Seems very joystick friendly as well.
Bruce Boaze ,
Yeah, 1 peddle driving, and if you want more regen you can push the regen paddles. However if you do touch the brakes, you are wasting some energy to brake-friction.
Mark Brooks : unlike pure electrics it doesn’t matter that your all electric range drops due to winter driving, because you have a backup engine!
Good point.
Also, with 53 EPA miles of electric range, in the winter that will drop to around 40, which is still enough to cover daily driving for most people.
And on hot summer days with the A/C on 100%, you also lose some range.
In addition, many of us aren't hyper-milers. In fact, with the Volt's smooth, silent acceleration, I've become even more of a lead-foot driver. All-electric drive is addictive. My wife has also become more aggressive driving the Volt. So that cuts range as well.
I'm really interested to see how the Gen2 Volt fares on www.voltstats.net. I suspect the extra range will make a dramatic difference for people who live in hot/cold weather and for people who like to floor it.
I've learned that if I lead with the regular brake before hitting the regen. paddle and finish with the brake rather than the paddle I can moderate the braking feel much better.
The paddle is great for doing a "brush brake" to get the weight to transfer to he front if in a high speed turn and there is a bit of understeer.
Don C, I can be wrong but I don't think what your doing us getting an analog response from you finger pressure or movement.
I suspect your either lead braking with the pedal or another method I think works most times is if you hit the paddle before your fully off the accelerator it seems to ease into the regen braking a but easier, but it seems to be affected by your current speed.
I believe I read the regen brake is variable by the computer based on forward speed.
Schmeltz : Yes, that would be interesting.Old vs. New.
We pretty much already know the Gen. 2 has been improved in every way, but it would certainly underscore that fact.They should show the two cars side by side, and go item for item to demonstrate what changed.
You can find a good side-by-side comparison of the Gen1 and Gen2 Volts here, written by Dustin Batchelor (Victoria, B.C., Canada):
http://drwattsonev.blogspot.com/2015/10/2011-vs-2016-chevy-volt-photo-comparison.html
Bruce
21 - 31 of 30 Posts
