1 - 9 of 9 Posts
My son accidentally pressed the red SOS OnStar Button today. After that, it seems that our radio will not work. The screen is on and actually stays on after the car is off. You can't hear anything through the radio and when you try to press buttons on the menu,everything seems greyed out. I called OnStar and they ran me through some random "refresh exercises" but it didn't work. I will try calling GM in the morning, but was hoping someone could assist me tonight. Thank you
Check and see if the red button may have gotten stuck in the depressed state.
That could gum up operation of the radio.
If the button is not stuck, pull the fuse for about 30 seconds.
If that doesn't work, disconnect the 12 volt battery for 10 seconds, which causes the whole car to reboot, same as your typical PC computer.
Discussion Starter #5
The SOS button was not depressed. So plan B. Disconnect the 12 Volt battery. Is that easy to do? Any safeguards? Thank you
Pull the fuse first. It is a lot easier. I think it is the left side dash fuse compartment.
If the fuse doesn't work, the battery should be under the hatch floor. The ground connection uses a 10mm bolt to tighten the clamp. Loosen the bolt a few turns with a nut driver or socket wrench, then jiggle the clamp until it lifts of the ground lug. Make sure the car is turned off first, though.
Discussion Starter #8
T-square! You are a genius my friend. I figured out how to open the fuse box, learned which fuse it was from the manual. Used a pair of pliers. Pulled it out carefully. Re-inserted the fuse and 60 seconds later, good as new! This is amazing, thank you.
Thanks to Shark Volt and TSquare, my problem is now fixed! What's next? I feel Like i can do anything now!
glad we could help.
1 - 9 of 9 Posts
