I think they just reset the display. Easy to change back to the “Enhanced” display. From the owner‘s manual:I recently had the SHVCS message & took it to the local dealer; 2014 with 63K on the clock. View attachment 171631
When I got it back, it seems to be OK but the dash display no longer includes the Accel/ Decel bouncing ball; it is simply replaced by a Gas Fuel guage in the form of a Fuel Pump. I'm wondering if I was given a software downgrade to early 2011 that ignores the coolant level sensor. Any thoughts?
jinxI think they just reset the display. Easy to change back to the “Enhanced” display. From the owner‘s manual:
Instrument Cluster Display Configurations
There are two instrument cluster display configurations to choose from. Press CONFIG to the left of the steering wheel to change the configuration. See Driver Information Center (DIC) on page 5‐41.
Choose either the Simple or Enhanced Configuration display.
The Enhanced Configuration displays the Driver Efficiency Gauge.
Duh, Thank you both for your help. When I bought the car new the Enhanced Configuration was displayed & never knew of the simple display.jinx
Not so fast, they are already back. You will even be able to buy a Corvette ($$$)!but for me, here in the AU, Holden don't even exist anymore, so I have one the most expensive pieces of abandonware in Australia anyway, and I'm pretty sure Mr Chevy wont be back in my country anytime soon as I think even our prime mincer would belt the crap out of him with old cricket bat.
Yeh just what Australia needs, more US oversized gas gusling penis extensions.Not so fast, they are already back. You will even be able to buy a Corvette ($$$)!
GMSV: New GM Cars for Sale in Australia & New Zealand
GMSV hand-picks the most ionic vehicles in GM's portfolio and brings them to Australia and New Zealand. Enquire online for additional information.www.gmspecialtyvehicles.com
Have you resolved this yet? I am in a similar predicament. I installed the defeat plug AFTER getting the SHVCS warning. I then cleared the error with a standard OBDII scanner which seemed to fix the problem for about 2 weeks before coming back on again. I cleared it a 2nd time and it came on again a day later. I took it to the dealership in hopes that it would be covered under the Voltec warranty, but it is not. They are asking for $950 to repair. $100 for the tank/sensor and the rest for 5 hours of labor to flush, fill and bleed the coolant system. I am tempted to have them just clear the codes and keep the vehicle in hold mode, so that I can reinstall the defeat plug before thHi - newest member with this problem. I think I've read every page and still have some questions.
Dealership reprogrammed after finding P1FFF and P0AA6 2 weeks ago. I don't know if they did hpcm2 and the BECM, but will find out today. SHVCS came back, and they now want $993 to replace the sensor of course. I'm handy with cars, but I'm no technician, so I have a few choices: 1) thinking about using a defeat plug, and then either buying a vcx nano to clear the SHVCS error or having my local shop do it for me, 2) trying to replace the sensor myself without replacing the coolant tank, and reprogram.
1) Does anyone have the part number for the sensor, and is there a walkthrough to replace?
2) Is the VCX easy enough to use? If so I'd much rather do this than go to the dealer every time, but has anyone posted instructions on doing this software update?
3) Since I already have the error, are these even my best options?
I've read a few accounts from members going through these steps and still being stumped, or having the defeat in place and the code coming back. I just want to take the most logical steps if someone can advise.
Thank you!
I replaced the sensor myself for $22 part #22922224, but the SHVCS warning came back. I purchased the VCX Nano to clear my own codes and update the software. It's a pita to install and learn, but it works very well after the learning period. If your software for the HPCM2 and BECM have not been updated, that would be your best starting place, even if you have the dealership or another mechanic with AC Delco SPS software do it.Have you resolved this yet? I am in a similar predicament. I installed the defeat plug AFTER getting the SHVCS warning. I then cleared the error with a standard OBDII scanner which seemed to fix the problem for about 2 weeks before coming back on again. I cleared it a 2nd time and it came on again a day later. I took it to the dealership in hopes that it would be covered under the Voltec warranty, but it is not. They are asking for $950 to repair. $100 for the tank/sensor and the rest for 5 hours of labor to flush, fill and bleed the coolant system. I am tempted to have them just clear the codes and keep the vehicle in hold mode, so that I can reinstall the defeat plug before th
Totally overpriced quote. Find another dealer.Hi - newest member with this problem. I think I've read every page and still have some questions.
Thank you!
100% correct. What was in the fix kit, or what part number?Totally overpriced quote. Find another dealer.
Just had my sensor replaced and it costed like..
And that includes shipping to Finland + EU import tax on US parts + VAT 24%
- GM fix kit about 90$
- Sensor about 60$
Labor (sensor change, HPCM2 reprogram including GM mandated measurements) was 200$ or about 1-2hrs on top of that.
993$ is just pure rip-off.
Based on the info on receipt it looks to be this below. (Other sites name it Connector Asm,Wiring Harness W/Leads)100% correct. What was in the fix kit, or what part number?
That's great info - thanks!Based on the info on receipt it looks to be this below. (Other sites name it Connector Asm,Wiring Harness W/Leads)
And now the actual monetary values (instead of from top of my head):
- Guided diagnostics (prolly means reading the codes, loading the PDF from GM and then reading the service manual) - 80€
- Labour - 149€
- GM fix kit - 19260759 - 57,20€
- Sensor - 22922224 - 34,09€
Total of 320€ ~ 350$.
