So what's your worst electric only mileage with a Gen II so far? Just did a 48 MPGe tonight on electric only. 20 degrees outside and snowing pretty decent. I burned as many kW in heating as I did to actually propel the car
Engine assisted heating was set to deferred since I knew I had the range (round trip to work and back including a stop for hot chocolate on the way home was only about 12 miles
). Two cycles of pre-warming the car with defrost and heated seats on climate control set to 80F and fan speed high. Then front and rear defroster and heated seat and steering wheel on and climate control on MAX while I headed home. Super comfortable but man it ate through the kW, lol.
Also, learned why I miss audible backup parking sensors so bad (and slightly better rear visibility). Back up camera was a nice clump of snow that I had to clean off before I backed into my garage, lol. Curious if it's safe to apply from AquaPel to it to try and promote snow buildup to slide off on its own... it's probably a plastic lens though so I don't want to damage that or haze it up....
