Guys, I'm the guy that drives the RAV4 EV. It has the following cold-weather features:
-Heat Pump and A/C: It's the same system, but runs in reverse for heat. The A/C is less of a drain on the battery than the heat. The reason for this is that heat pumps lose their effciency as the outside temp falls. Both systems are quite powerful, the heat will toast you and the A/C will freeze you. The RAV4 has quite a large cabin, and the sun is brutal here in summer and the winter is bitter cold. The air is also very dry, so it doesn't store heat very well. The RAV4 also has clear glass so the solar gain is brutal as well (soon to be rectified with aftermarket tint). The point is that electric-driven heat-pump and A/C can keep up quite well with conditions without huge strains on the battery.
-Heated seats: Hi and Lo, works great
-Rear defroster: standard, but on a timer
-Heated windshield: The inner layer between the glass sandwich is heated. Very, very neat. Melts ice and snow directly with no air blowing.
-Pre-heat and pre-cool on shore power: Very nice. Set the timer, and the car will be heated and cooled from the wall, leaving you ready to drive with a full battery.
Just a side note, cold and snowy or wet weather has other range implications. The heat pump is a piece of it. I believe I've listed all of them in another thread.
So, to answer the question, a car can be fully heated and cooled without burning anything, in fact, the heated windshield is awesome.
Nate
