Up here in the North Country, I have had a winter front installed on other cars. It covers part or all of the front grill to limit the flow of cold air to the radiator. Some people call it a grill block. You often see them on diesel trucks. It helps to heat up the car faster, and some people say it improves gas mileage, and I suppose perhaps electric range.
Has anyone done this with the Volt? Have you seen any benefit? Is there a simple DIY way to do it? It should be easy to install and remove, since you want to remove it for those warmer days of January thaw.
