What would be the possibilities of using a turbine engine rather than a piston engine in the volt to generate the electricity? It seems like a match made in heaven. A turbine engine is 2x as efficient as a piston engine weighs half as much and is much more compact. Not to mention far fewer moving parts. In theory you could at least double it's mpg while it's utilizing gas/e85 to keep the battery charged. I'm no expert on turbine engines though. Would this be possible? I know GM made and tested a turbine powered car, but it never worked all that well because of the variable speeds needed for a direct drive turbine car, but this seems like a match made in heaven. Your thoughts please
