The Tesla/Bolt big battery have a cost problem, plus its not clear that the infrastructure can scale up for people's normal road trips needs for reliable transportation over the holidays. 30-60 minutes charging for every 3-4 hours driving is a bit of a hassle too.I also believe liquid fuel range extenders will be around much longer than people think.
Hassle? Really? Doesn't that describe life as a human? At some point the body needs to stop.... people's normal road trips needs for reliable transportation over the holidays. 30-60 minutes charging for every 3-4 hours driving is a bit of a hassle too. ....
The bigger problem is the shear number of superchargers required as we approach 100% electric cars. Of course, for many people, an EV with sufficient fast charging infrastructure will be fine, and stopping a little longer and a little more often will be fine. But not for all drivers. But building a sufficient infrastructure to adequately support 100% EV peak travel, and supporting it with the grid .... imagine every single gas station along the interstate replaced with a parking lot full of hundreds of superchargers all simultaneously drawing 100kw each ...Hassle? Really? Doesn't that describe life as a human? At some point the body needs to stop.
You can do the big-sport-drink-bottle method if you are solo, but the gasser still needs to stop for fuel at some point.
And, as always, that EV fuel can be locally and sustainably produced. THAT should be an important factor.
So on a road trip, get up off you ass and take a walk for the extra 20-30 mins required to recharge your EV.
Your body will thank you!
Batteries are likely to get cheaper over time. But a factor that may take much longer for EV proliferation is charge time/mile. Otherwise BEVs will not be expensive, and they are relatively cheap to maintain. ICEs on the other hand "charge" quickly but are expensive to maintain. Thinking about the Voltec, it has the worst of both sides of this equation. It will be interesting to see where the market goes.30-60 minutes charging for every 3-4 hours driving is a bit of a hassle too.
Then there's the good old internal combustion engine with a Prius style hybrid. Its relatively inexpensive
It may take awhile before the internal combustion engine is retired.... its too hard to compete with.
It all comes down to energy density. If the energy density of batteries doubles then charge time won't be important at all. There have been a lot of experimental battery types that have demonstrated 2X or better energy densities, enough that we can be confident that sometime in the near future (5-10 years) there will be a practical battery that has at least 2X the energy density of today's batteries. A 2X improvement gives you a Bolt with 480 miles of range, a little more than the combined range of the Volt which for me is around 460. The magic number is 400 miles, at that range you will almost never need to charge on the road. In the summer I do long day trips every weekend, starting out in the morning and coming home late at night. In the two summers that I've had the Volt the longest trips were 385 miles, to Pemaquid Light in Maine, and 375 miles to Warren Vt. The Volt did both of those trips without refueling and I returned home with two gallons in the tank. A BEV with an EPA rating of 400 miles or better would also be able to do those trips without recharging. The only way that you can exceed 400 miles in a day is on an Interstate. Even on an Interstate you would need to stop every 200 miles or so because of the limitations of the human bladder, you would also want something to eat after 4 or 5 hours of driving. At today's Tesla Supercharger speeds you can add 60KW, over 200 miles of range, in 30 minutes which is about the time it would take to eat a quick meal. EVs differ for ICE cars in that they are always fully charged in the morning so the range really is the range, the gas tanks of ICE cars are filled as needed so the range to your first stop can be much less than your full range. In a world of EVs everyone would be plugged in at home so they won't need any local fast charging, except maybe in cities but even there lot's of buildings have parking lots and garages and lightpole chargers might prove to be a better solution than central fast chargers. When taking the family to Wally World you would expect that motels will all have EVSEs so with a 400 mile range car chances are you won't need to charge on the road, but even if you do you will combine it with a pee and snack break.Batteries are likely to get cheaper over time. But a factor that may take much longer for EV proliferation is charge time/mile. Otherwise BEVs will not be expensive, and they are relatively cheap to maintain. ICEs on the other hand "charge" quickly but are expensive to maintain. Thinking about the Voltec, it has the worst of both sides of this equation. It will be interesting to see where the market goes.
Pausing 30-60 minutes every 2-5 hours of driving is actually very very healthy for you! Just standing and walking around after every hour of sitting in your desk job is recommended by the doctors to prolong your life.The Tesla/Bolt big battery have a cost problem, plus its not clear that the infrastructure can scale up for people's normal road trips needs for reliable transportation over the holidays. 30-60 minutes charging for every 3-4 hours driving is a bit of a hassle too.
Technically this works very well. But it still requires a culture change about how we use and fuel our cars. In school I remember driving across country with 3 drivers, stopping only long enough to fuel up, pee, and grab a sandwich -- not nearly long enough to charge the car.It all comes down to energy density. If the energy density of batteries doubles then charge time won't be important at all. There have been a lot of experimental battery types that have demonstrated 2X or better energy densities, enough that we can be confident that sometime in the near future (5-10 years) there will be a practical battery that has at least 2X the energy density of today's batteries. A 2X improvement gives you a Bolt with 480 miles of range, a little more than the combined range of the Volt which for me is around 460. The magic number is 400 miles, at that range you will almost never need to charge on the road. In the summer I do long day trips every weekend, starting out in the morning and coming home late at night. In the two summers that I've had the Volt the longest trips were 385 miles, to Pemaquid Light in Maine, and 375 miles to Warren Vt. The Volt did both of those trips without refueling and I returned home with two gallons in the tank. A BEV with an EPA rating of 400 miles or better would also be able to do those trips without recharging. The only way that you can exceed 400 miles in a day is on an Interstate. Even on an Interstate you would need to stop every 200 miles or so because of the limitations of the human bladder, you would also want something to eat after 4 or 5 hours of driving. At today's Tesla Supercharger speeds you can add 60KW, over 200 miles of range, in 30 minutes which is about the time it would take to eat a quick meal. EVs differ for ICE cars in that they are always fully charged in the morning so the range really is the range, the gas tanks of ICE cars are filled as needed so the range to your first stop can be much less than your full range. In a world of EVs everyone would be plugged in at home so they won't need any local fast charging, except maybe in cities but even there lot's of buildings have parking lots and garages and lightpole chargers might prove to be a better solution than central fast chargers. When taking the family to Wally World you would expect that motels will all have EVSEs so with a 400 mile range car chances are you won't need to charge on the road, but even if you do you will combine it with a pee and snack break.
I don't see how it involves a culture change. You don't do a lot of extreme road trips in you life and when you do it doesn't matter what obstacles you have to overcome, that's the fun of a trip like that. My most extreme trip was in the early 90s. One day in the summer I decided to see how far North I could go so I pointed the LeBaron GTS North and drove until I was in Labrador. It involved two ferries, one from New Brunswick to Newfoundland and one from Newfoundland to Labrador. In Labrador the roads ran out, there was no way go go any farther so I came back via Nova Scotia. You couldn't do that trip in an EV today but I wouldn't be surprised if it was possible in 10 years. Your trip sounds like something a friend of mine did in the late 70s. Someone at work suggested that they go our for ice cream, someone else said he knew a great place, where was it, San Francisco, so they hopped in a car in Maynard MA and drove straight through to San Francisco. You only do something like that when you are young and you don't do it more than once.Technically this works very well. But it still requires a culture change about how we use and fuel our cars. In school I remember driving across country with 3 drivers, stopping only long enough to fuel up, pee, and grab a sandwich -- not nearly long enough to charge the car.
Is this you, Barry? Remember me from DEC days?I don't see how it involves a culture change. You don't do a lot of extreme road trips in you life and when you do it doesn't matter what obstacles you have to overcome, that's the fun of a trip like that. My most extreme trip was in the early 90s. One day in the summer I decided to see how far North I could go so I pointed the LeBaron GTS North and drove until I was in Labrador. It involved two ferries, one from New Brunswick to Newfoundland and one from Newfoundland to Labrador. In Labrador the roads ran out, there was no way go go any farther so I came back via Nova Scotia. You couldn't do that trip in an EV today but I wouldn't be surprised if it was possible in 10 years. Your trip sounds like something a friend of mine did in the late 70s. Someone at work suggested that they go our for ice cream, someone else said he knew a great place, where was it, San Francisco, so they hopped in a car in Maynard MA and drove straight through to San Francisco. You only do something like that when you are young and you don't do it more than once.
It may get you there a few hours faster than the other way, but it sounds so unpleasant compared to "drive half a tank, get out and walk for ten minutes, drive the other half tank, fuel, pee, have a meal someplace someone brings you the food while sitting on something OTHER than a car seat, change drivers and go on."Technically this works very well. But it still requires a culture change about how we use and fuel our cars. In school I remember driving across country with 3 drivers, stopping only long enough to fuel up, pee, and grab a sandwich -- not nearly long enough to charge the car.
Talk about going "North", you should read North to The Night, great adventure book.I don't see how it involves a culture change. You don't do a lot of extreme road trips in you life and when you do it doesn't matter what obstacles you have to overcome, that's the fun of a trip like that. My most extreme trip was in the early 90s. One day in the summer I decided to see how far North I could go so I pointed the LeBaron GTS North and drove until I was in Labrador. It involved two ferries, one from New Brunswick to Newfoundland and one from Newfoundland to Labrador. In Labrador the roads ran out, there was no way go go any farther so I came back via Nova Scotia. You couldn't do that trip in an EV today but I wouldn't be surprised if it was possible in 10 years. Your trip sounds like something a friend of mine did in the late 70s. Someone at work suggested that they go our for ice cream, someone else said he knew a great place, where was it, San Francisco, so they hopped in a car in Maynard MA and drove straight through to San Francisco. You only do something like that when you are young and you don't do it more than once.
No doubt it is unpleasant, but when you are young you don't care about that stuff. Now I hate driving more than a few hours without a prolonged stop.It may get you there a few hours faster than the other way, but it sounds so unpleasant compared to "drive half a tank, get out and walk for ten minutes, drive the other half tank, fuel, pee, have a meal someplace someone brings you the food while sitting on something OTHER than a car seat, change drivers and go on."
I was never at DEC, my ex business partner Herb was. I started at Data General, I was one of the Soul of a New Machine kids.Is this you, Barry? Remember me from DEC days?
Anker
