It is a personal choice. If you like to build things then OpenEVSE is the Heathkit of the EVSE world. Many have high praise for ClipperCreek and their LCS series and HCS series of EVSE. Well designed EVSE with none of the frills (no WiFi, no display panel only status lights.) 3 year warranty and a strong customer service department. Other brands include Chargepoint, Siemens and Juicebox. Some choose to save some $ and purchase a Level 2 EVSE from an off-shore supplier. You can find these for sale on ~zon and ~bay. They may not last as long as an EVSE from a first line brand but then again the off-shore EVSEs generally cost half as much as the name brand EVSEs (i.e., ClipperCreek LCS-20) for an equivalent power rating, capable of charging an EV/PHEV at 230V and up to 16 amps.Since there is a few Level 2 chargers out there now, I am wondering which one to get.
what charger you have and what you like or don't like about it?
I will have to check this out! I love building things.I like the OpenEVSE equipment. They are very good value for money, top quality components, provide many features not available in other EVSE's and the price is very reasonable. You can also buy the kit version, put it together yourself and save a couple of hundred....
https://www.openevse.com/
Great deal here with quality parts. My son has been using it a while now on his Volt.Since there is a few Level 2 chargers out there now, I am wondering which one to get.
I wonder if this is actually Clipper Creek's portable EVSE charger. The Gen 2 Volt's OEM EVSE is Clipper Creek but the Clipper Creek web-site doesn't list any portable EVSE equipment.Also consider this AmazingE:
https://amazing-e.com/
It is essentially a cheaper clipper Creek unit, made in USA with a three-year warranty, just with the smaller Volt OEM style portable housing (that one is also made by clipper Creek). Be advised it does only come with a 20 foot cord though, that’s the only significant drawback I see with it.
I think it is. It appears to have same housing as the GM oem version made by them and has a Clipper Creek warranty. For some reason they don’t want to use the Clipper Creek name....I wonder if this is actually Clipper Creek's portable EVSE charger. The Gen 2 Volt's OEM EVSE is Clipper Creek but the Clipper Creek web-site doesn't list any portable EVSE equipment.
Per the ClipperCreek website, the charging power of the LCS-20 is 16 amp (3.8kW max.) The required supply circuit is 208V/240V @ 20 amp.I got a used Clipper Creek LCS-20 from another forum member, and I love it. It is VERY well-built and I'm confident it will outlive the car. It's a hardwired version so I can take it with me when I move and wire on whatever plug I need. It will provide 4.8 KW, so even though it's more than my Volt can take, if anyone else in the house gets a BEV like a Bolt, they should have no issue. I plan on actually relocating it to the exterior of the garage since it is durable enough for it, and it will provide more flexibility for where I can park.
I do regret not having WiFi though, and I discovered the OpenEVSE after my purchase. I'm pretty tech savvy, and for the WiFi advantage I sometimes regret not getting that instead. I cannot speak for its durability, though.
Ahh yes you're right. I don't have the LCS-20, I have an LCS-25, which supplies 20 amps or 4.8 Kw (slightly confusing as to why they couldn't use the number to specify amps).Per the ClipperCreek website, the charging power of the LCS-20 is 16 amp (3.8kW max.) The required supply circuit is 208V/240V @ 20 amp.
I've never had an issue with coiling and uncoiling the 25 ft. length of the charging cord on my ClipperCreek EVSE. I appreciate the flexibility a longer charging cord provides. In any event you would be hard pressed to find a charging cord much longer than 28 -30 ft. without using an EVSE charging extension cord (these do exist, are not inexpensive.)
