The dealer sells AC Delco touch up paint. Which one do you recommend ?
Agreed. A little polishing compound afterwards can help it blend in. It will run less if you just dab it on in little spots with a toothpick.I purchased AC Delco lacquer touch up paint (Summit White) at my local auto parts store. It comes fitted with a pen tip applicator that can be removed to access the brush inside.
It's touch up paint. Touch up paint rarely matches the color of the vehicle, impossible to apply evenly on a vertical surface without some of the paint running down the side of the affected area. It protects the underlying metal better than not.
