Thanks very informative. So a 100,000 miles on ICE only car will still have a better battery than a 100,000 miles on battery only car.
In theory, yes.Thanks very informative. So a 100,000 miles on ICE only car will still have a better battery than a 100,000 miles on battery only car.
I wonder if as the battery wears, whether the software on board slightly opens up the SOC to continue to give you around 38 miles of range (in a gen 1). It's not cheating, but using up a little leftover buffer. It's almost like these new solid state drives where they have several extra megabytes on board that are unused, and as the flash memory bits fail, new ones are used as replacements and the user doesn't know any different.In addition to the battery difference likely being unmeasurable (especially without specialized analysis), it'll likely stay unmeasurable for several more years of all-electric driving, and when it begins to fail, it'll likely manifest as getting slightly less all-electric range before using the near-new engine. The reverse situation, where the engine has 100,000 miles on it and the battery virtually unused is that the engine is your backup. And if that becomes your "usable life" measurement before replacing the car, not wanting to use the ICE because it's unreliable is a bigger blocker than "The thing switches to reliable ICE after only 28 miles".
So if it's a choice between a car with many gas miles versus many battery miles, the one with many battery miles is probably going to last longer and be cheaper in that long term than the one that's "saved" its battery life for so long, at the expense of the gas powertrain.
I wondered the same thing. Also thought that once beyond warranty perhaps someone would create a hack so you could do it yourself.I wonder if as the battery wears, whether the software on board slightly opens up the SOC to continue to give you around 38 miles of range (in a gen 1). It's not cheating, but using up a little leftover buffer. It's almost like these new solid state drives where they have several extra megabytes on board that are unused, and as the flash memory bits fail, new ones are used as replacements and the user doesn't know any different.
It's been a common speculation or assumption. We have explicit statements from our GM folks that it does not happen, and I've never seen any evidence that it does.I wonder if as the battery wears, whether the software on board slightly opens up the SOC to continue to give you around 38 miles of range (in a gen 1). It's not cheating, but using up a little leftover buffer. It's almost like these new solid state drives where they have several extra megabytes on board that are unused, and as the flash memory bits fail, new ones are used as replacements and the user doesn't know any different.
I see conflicting answers on this question. Some say that when you run out of battery (and driving in normal mode), the gas engine charges the battery, which drives the wheels. Others say the gas engine drives the wheels directly without charging the battery.
Does anyone know for sure?
This is important because if it's the latter, the battery is basically untouched (and thus will have longer life) when in gasoline engine mode.
[/Q
Chevrolet Volt Drive SimulationI see conflicting answers on this question. Some say that when you run out of battery (and driving in normal mode), the gas engine charges the battery, which drives the wheels. Others say the gas engine drives the wheels directly without charging the battery.
