Can anyone help me figure this out? I assume this noise is from the Voltec unit. (Louder on the driver's side.) I already checked, it's not the radiator cooling fans. Raising the hood starts the engine, so I stuck my smartphone under the the engine to record the sound. At first, when the car was in the driveway, I thought I heard a cricket under the hood. Then, in the quiet of the garage, it was more discernible. Noise is only present in Park and Neutral. No sound at all in R, D and L (with parking brake firmly engaged!) Makes the sound even when plugged in (though I can't move the shifter out of P when plugged in.)
I''d appreciate hearing from others (pun intended) as to whether they have the same noise.
You'll need to turn up the speaker volume to hear it. Sorry, it's just a smartphone recording. I recorded the sound in both P and N -- essentially the same noise. Chirping, possibly rotational noise. Fans inside the inverter box? Noise is present both in the morning (before first drive of the day) or also otherwise, when the car is hot.
http://mama.indstate.edu/users/chat/InPark.m4v
http://mama.indstate.edu/users/chat/InNeutral.m4v
Thanks!
2014-05-23 UPDATE: It DOES make the noise in R, D & L. Sorry. I guess I just wasn't hearing it as loudly. -b
Thanks!
