I get monthly reports from Chev on the cars mileage. They claim 240 KW/100miles. But the car claims 200KW/100 miles...that is a 20% error. I do not take short trips. Does anybody know which is correct.?
This. What's displayed on the screen inside the car does not account for charging losses. The monthly OnStar report numbers do include estimated charging losses.The discrepancy of 20% is within the possibility of charging losses as well as temperature control on the battery pack during charging procedures. I don't believe the car takes into account those factors and only what is used to propel the car which could account for the difference. On a side note, 240KW/100 miles seems VERY excessive. Are you sure its not watts/mile or 24.0KW/100 miles?
Just don't use it all the time. Get a baseline measurement then get the kill-a-watt out of the circuit. Seems the continuous load has caused some to melt down and burn out.If you are charging using your L1 cord at home get a Kill a Watt power meter and keep track of your kWh usage and your EV miles.
That will give you true Wall to Wheels costs.
That's actually pretty common efficiency for a Volt. Careful driving in good weather actually gets it close to 5 miles per kWh (from battery, not wall).Even still, 24 kWh/100 miles is an impressively efficient number for a Gen 1 Volt.
I would not say common, I would say rare but achievable. I would say most common efficiency for Gen 1 is averaging 3.5-4 miles/kWh.That's actually pretty common efficiency for a Volt. Careful driving in good weather actually gets it close to 5 miles per kWh (from battery, not wall).
