No, don't hold that up to your forehead unless you buy a Prius.
No, don't hold that up to your forehead unless you buy a Prius.Because Im an idiot and was looking at a Prius when I was typing that.... It is indeed an L.... like the one I am holding up against my forehead right now... lol
This is not a GM problem that there is a lack of DCFC. It is coming. These are still the early days for us early adopters!... Most likely CA... where ... We have virtually NO DCFC units. As far as the range goes, ...the reality is that if you drive a lot of highway, it will go down..
Yep thats exactly what I am saying... SO WHY DECREASE THE RANGE ON A VEHICLE THAT NEEDS IT MORE THAN ANY OTHER....As for 'range'; are implying that the Spark EV requires more power to go highway speeds, just like every other vehicle on earth?
GM shortened the gear ratio on the 2015 Spark, but there is no evidence to suggest that this has hurt range on the freeway. You could be right, but no one has done testing between 2015 and 2014 to confirm what you are saying.Yep thats exactly what I am saying... SO WHY DECREASE THE RANGE ON A VEHICLE THAT NEEDS IT MORE THAN ANY OTHER....
Didn't they also change battery companies at the same time? I seem to recall they shortened the final gear ratio in concert with a battery change.GM shortened the gear ratio on the 2015 Spark, but there is no evidence to suggest that this has hurt range on the freeway. You could be right, but no one has done testing between 2015 and 2014 to confirm what you are saying.
Sent from my iPhone 8
I was using sarcasm, Drag increase with the square of velocity. No matter what the vehicle.Yep thats exactly what I am saying... SO WHY DECREASE THE RANGE ON A VEHICLE THAT NEEDS IT MORE THAN ANY OTHER....
Yes they did. But it is my understanding that even though the Battery got smaller, the percent of the battery that is actually used stayed the same. The battery on the 2014 model is a 21 kWh battery, but only 18.4 kWh is usable. I think the 2015 has a 19 kWh battery but it still uses 18.4 kWh of that 19.Didn't they also change battery companies at the same time? I seem to recall they shortened the final gear ratio in concert with a battery change.
Link please? (that kid has a history of crapping on GM products or anything with an SAE CSS plug. lol)Tony Williams tested one and it showed a 10 mile decrease
Sorry.It wasn't meant to be rude or disrespectful, but moderators are permitted to have opinions too and that is mine. It's just you seem to be content on making a lot of "noise" over what to this point appears to be unsubstantiated data (most people post links to supporting information if/when they start "yelling" in a forum)Are you saying the 2014 with the A123 battery doesnt have the cooling system as the LG does?
The link is from the mychevysparkev forum... I will try and find it for you...
And what is with you saying my post is much ado about nothing? Really? To me its something. As a moderator, you should be the last one to be so rude.
It's a compliance car , so they may decide to dump it once the Bolt becomes available .Too bad only residents in 3 states get the spark EV goodness, I don't think the remaining 50'will get spark at all, but here's hoping we will all be able to buy the Bolt
