The other day I had a brilliant idea, the kind of idea that, when I was working for a living, I'd get a cash prize for: I had this "old" iPhone 4, which works just fine but is really pretty obsolete for many apps and purposes. It's not activated, but I could still make a 911 call on it in a real emergency. I might have used it as an iPod, to listen to music to in the car, but I never do that. Then I remembered "Find My iPhone" -- the Apple app that lets you locate (on a map, thanks to GPS, etc.) an Apple device -- such as an iPhone 4! So I'm keeping this old phone in the box between the front seats. If somebody steals the car, I can use Find My iPhone on another device to locate the phone (and the car). So if you have an old iPhone or iPad somewhere that you no longer have a use for, consider this.
Then I plugged it in to the USB port in the box and it started charging -- even without the car being turned on! Is that right? Is there supposed to be power to the USB port when the car's not powered up? I thought I remembered reading that the cigarette lighter jack lost power when the car was turned off, and I assumed it'd be the same with the USB port.
Finally, and on a completely different subject: one of my tires is driving me nuts. I keep filling all four tires to 42 psi, and my right rear tire keeps dropping to 40 psi by the next morning. And stays there, at 40 psi! I've done this two or three times now. It's like there's a tiny slow leak that just won't go below 40 psi. Kind of like it's thumbing its nose at me. Really irritating me!
It may not be the tire but the wheel that is leaking air...GM has had this problem in the past...
Tires/Wheels - Low Tire/Leaking Cast Aluminum Wheels
TECHNICAL
Bulletin No.: 05-03-10-003F
Date: April 27, 2010
Subject: Low Tire Pressure, Leaking Cast Aluminum Wheels (Repair with Adhesive Sealant)
Models:
2011 and Prior GM Passenger Cars and Light Duty Trucks (Including Saturn)
2010 and Prior HUMMER H2, H3
2009 and Prior Saab 9-7X
with Cast Aluminum Wheels
Supercede:
This bulletin is being revised to update the model years and the bulletin reference information. Please discard Corporate Bulletin Number 05-03-10-003E (Section 03 - Suspension).
Condition
Some customers may comment on a low tire pressure condition.
Diagnosis of the low tire pressure condition indicates an air leak through the cast aluminum wheel.
Cause
Porosity in the cast aluminum wheel may be the cause.
Notice: This bulletin specifically addresses issues related to the wheel casting that may result in an air leak. For issues related to corrosion of the wheel in service, please refer to Corporate Bulletin Number 08-03-10-006C - Tire Slowly Goes Flat, Tire Air Loss, Low Tire Pressure Warning Light Illuminated, Aluminum Wheel Bead Seat Corrosion (Clean and Resurface Wheel Bead Seat).
Correction
Remove the tire and wheel assembly from the vehicle. Refer to the appropriate service procedure in SI.
Locate the leaking area by inflating the tire to 276 kPa (40 psi) and dipping the tire/wheel assembly in a water bath, or use a spray bottle with soap and water to locate the specific leak location.
IMPORTANT - If the porosity leak is located in the bead area of the aluminum rim (where the tire meets the rim), the wheel should be replaced.
IMPORTANT - If two or more leaks are located on one wheel, the wheel should be replaced.
If air bubbles are observed, mark the location.
If the leak location is on the tire/rubber area, refer to Corporate Bulletin Number 04-03-10-001F
Tire Puncture Repair Procedures for All Cars and Light Duty Trucks.
If the leak is located on the aluminum wheel area, continue with the next step.
Inscribe a mark on the tire at the valve stem in order to indicate the orientation of the tire to the wheel.
Dismount the tire from the wheel. Refer to Tire Mounting and Dismounting.
Remove the tire pressure sensor. Refer to Tire Pressure Sensor removal procedure in SI.
Scuff the INSIDE rim surface at the leak area with #80 grit paper and clean the area with general purpose cleaner, such as 3M(R) General Purpose Adhesive Cleaner, P/N 08984, or equivalent.
Apply a 3 mm (0.12 in) thick layer of Silicone - Adhesive/Sealant, P/N 12378478 (in Canada, use 88900041), or equivalent, to the leak area.
Allow for the adhesive/sealant to dry.
Notice: Caution must be used when mounting the tire so as not to damage the sealer. Damaging the repair area may result in an air leak.
Align the inscribed mark on the tire with the valve stem on the wheel.
Reinstall the Tire Pressure Sensor. Refer to Tire Pressure Sensor installation procedure in SI.
Mount the tire on the wheel. Refer to Tire Mounting and Dismounting.
Pressurize the tire to 276 kPa (40 psi) and inspect for leaks.
Adjust tire pressure to meet the placard specification.
Balance the tire/wheel assembly. Refer to Tire and Wheel Assembly Balancing - Off-Vehicle.
Install the tire and wheel assembly onto the vehicle. Refer to the appropriate service procedure in SI.
