Argh.. PGE is asking for a 7% increase in electric rates for residential customers. A kwh will rise to .12 or slightly above. Wondering if this is going to be a trend across all the US? Maybe the net zero sustainability strategy has something to it
I can't believe that's true. I'm an hour away from you and pay about $0.12 a kWh, when all fees etc. are factored in.Damn. We pay $0.037 a kWh.
Well, in my area we have National Grid (I assume you too, but not certain), and there's a $/kWh charge for supply, and also a $/kWh charge for delivery. Those added up equates to about $0.12/kWh, you need to make sure you add up both for the "real" price you pay for each incremental kWh used. Then there's a $20 base charge that they tack on for the privilege of paying them for the service, which can also increase the effective rate a fair amount when you take your total electric bill and divide by your total kWh used.I'm not sure how to calculate all said and done, but on our bill itemization that's the cost of a kWh. Some of our power comes from the Erie Canal. Fairport ny has basically free electricity because of this. A high electric bill for a residential house in fairport is like $50 I was told a year ago when we where looking at houses.
I'll see if I can find the last bill and see. We get it through RGE but not sure who gives them the power or how that all works but I'll get numbers for you later.Well, in my area we have National Grid (I assume you too, but not certain), and there's a $/kWh charge for supply, and also a $/kWh charge for delivery. Those added up equates to about $0.12/kWh, you need to make sure you add up both for the "real" price you pay for each incremental kWh used. Then there's a $20 base charge that they tack on for the privilege of paying them for the service, which can also increase the effective rate a fair amount when you take your total electric bill and divide by your total kWh used.
While the electric provider does charge a "base rate" even though you may not use any electricity, is it appropriate to include that in the cost of a kWh? The cost of each incremental kWh you consume is not impacted by that "base rate". Mine is based on a daily charge for just having the service, meter reading, billing, etc. so I don't see why those charges should be logged against the incremental cost of a kWh - you pay them no matter what, with each kWh increasing the overall bill based on the other consumption fees. My electric bill has 18 line items total with 11 associated with charges for each kWh. So I feel those 11 items are the only fees that impact the cost of each kWh.<snip>.....Then there's a $20 base charge that they tack on for the privilege of paying them for the service, which can also increase the effective rate a fair amount when you take your total electric bill and divide by your total kWh used.
First off, I want to apologize to the OP for having caused a bit of a tangent here.Just my $0.02 worth.
There may be negative impacts, but it is a more accurate way of paying for electricity. Paying for everything by kWh does not accurately reflect costs. If it's a problem for people on low incomes to pay more accurate prices for electricity then there's a problem with incomes, not the electricity pricing.As an example, near me, National Grid recently INCREASED the base charge for electricity, but DECREASED the rate for each kWh delivered. Personally, I was very against this, but not because I did or did not benefit from the change. The reason is simple: Poorer families have smaller homes and use much less electricity, so under this proposal, they effectively pay much more per kWh they use. Richer families pay less since they use so many more kWh. Additionally, this approach DISCOURAGES conservation of energy because everyone is now paying less per kWh (the part they can control) and more on the base charge (the part they cannot control). This effective increase also discourages solar installations, who often zero out their "per kWh" charges thanks to net metering, but always have to pay the base charge.
We don't really know what "accurately" reflects costs without looking into things more. In the case of National Grid, I don't believe they were increasing the base charge to accurately reflect costs. But either way, "accurate pricing" is not always the appropriate way to approach rates, is it? I think at that point it is just as subjective as everything else I've stated. I'm not a huge fan of policies that redistribute wealth or similar, but in the case of something as fundamental as electricity and the security that provides, I do think it's important to structure rates in a way that make electricity, overall, less expensive when you use less, and more expensive when you use more, down to, say, 150kWh per month.There may be negative impacts, but it is a more accurate way of paying for electricity. Paying for everything by kWh does not accurately reflect costs. If it's a problem for people on low incomes to pay more accurate prices for electricity then there's a problem with incomes, not the electricity pricing.
You're not alone, I'm right there with you, haha. Although I'd rather see fuel costs increase instead of electricity rates. Significant electricity rate increases would be "Phase 2" of that "Evil plan" in my book, with Phase 1 being the significant increase of the cost of gasoline.How come I'm always the weirdo when it comes to finances, electric rates, fuel costs, etc. I'd love to see my electric rates triple or quadruple as that would make the ROI on a giant solar array and a few powerwalls finally make financial sense.
This is the only true way to determine your per kWh cost. This is what is coming out of your pocket.<snip> ...take your total electric bill and divide by your total kWh used.
Same here. $0.1245 with all taxes and fees.Here in southern Illinois with AmerenIP my all in cost for kW is just at 12 cents. I take the total $$$ of my bill and divide that by the total number of kW's reported.
I give up trying to figure all the individual line items of charges.
