1 - 20 of 82 Posts
Super Moderator
I liked their description...because it breaks it down fairly simply info *four* modes...I was not trying to raise the controversy again and bring out the haters/trolls.
a) http://www.designnews.com/article/511165-Electronics_Boost_Chevy_Volt_s_Efficiency.php
Electronics Boost Chevy Volt's Efficiency - The Chevy Volt is more than a green vehicle. It's a smart, seamless driving machine that in some cases exceeds the performance of gas-burning cars.
Charles J. Murray, Senior Technical Editor, Electronics -- Design News, November 16, 2010
<snip>
Voltec drive unit now has four basic modes of operation: electric driving (low- and high-speed); and extended range driving (low- and high-speed).
Here's a quick look at the four modes as described in the article [] are additions:
Electric Low-Speed [in Charge-Depleting (CD) mode]: The simplest and most well-known of the Volt's four modes, this calls for the vehicle to use the charge from its 435-lb lithium-ion battery pack to power a 111-kW ac traction motor. When the traction motor turns, it transmits power to a sun gear in a planetary gear set, which turns the drive axle. Volt owners are expected to make heavy use of this mode - many will drive the car to work and back, charge it at night, and never use a drop of gasoline in the process.
Electric High-Speed [in Charge-Depleting (CD) mode]: The Volt typically hits this mode at about 70 mph. Then, the supervisory controller splits the power between the large traction motor and a smaller 54-kW generator-motor (which is still operated by the battery). The planetary gear set blends the power from the two motors and sends it to the drive axle. Even as it switches to this mode, however, the Volt still isn't employing its internal combustion engine - and therefore still isn't burning any gasoline.
Extended Range Low-Speed [in Charge-Sustaining (CS) mode]: When the battery's charge drops to an unacceptable level, the 1.4-â„“ I-4 engine makes its debut. At low speeds, the engine spins the generator-motor, which replenishes the battery.
Extended Range High-Speed [in Charge-Sustaining (CS) mode]: This is the most complicated and controversial (see sidebar) of the Volt's four modes. With the battery depleted at higher speeds (70+ mph), the controller opts for a power split. It calls for power to be delivered through the big traction motor and through the smaller generator-motor. Unlike the other modes, however, this one calls for the generator-motor to transmit power directly into a ring gear in the vehicle's planetary gear set. GM says it has a good reason for doing this - electric motor efficiency typically plummets at higher speeds. "You're bringing down the speed of the main traction motor and supplementing it with the generator-motor," a GM spokesman says. "As a result, you're improving the efficiency."
<snip>
Sidebar:
So is it an EV? Or a hybrid? To be sure, there's no direct connection between the gasoline-burning engine and the Volt's planetary gear set. Rather, the engine delivers power to the vehicle's generator-motor, which relays it to the ring gear of the planetary gear set. The bottom line is it's not a direct mechanical connection in the manner of a conventional gas-burning car, but the generator-motor arrangement is similar to that of a Toyota Prius, which is a true hybrid.
Still, GM insists the Volt should still be considered an EV. "It's clearly an electric vehicle," says Pamela Fletcher, global chief engineer for the Volt and for GM's plug-in hybrid electric powertrains. "You can accelerate from a stop to 100 mph and have the engine never come on. You could take the internal combustion engine out of it, and it would drive just fine. But if you took the battery out, it wouldn't drive."
b) Another excellent article with pictures (thanks WOT and others):
Chevy Volt Delivers Novel Two-Motor, Four-Mode Extended Range Electric Drive System; Seamless Driver Experience Plus Efficiency
http://www.greencarcongress.com/201...-electric-drive-system-seamless-driver-e.html
c) Deep dive videos: http://www.youtube.com/results?search_query=Chevy+Volt+Powertrain+Deep+Dive
I do not like this explanation at all. Misleading at best and wrong in at least one case. Examples follow (and it's not just semantics):
“At low speeds, the engine spins the generator-motor, which replenishes the battery.”
I think it is more correct to say: At low speeds, the engine spins the generator-motor. This provides electrical power directly to the traction motor. It also periodically charges the depleted battery just enough to maintain a small reserve for higher power needs, such as hard acceleration.
“Unlike the other modes, however, this one calls for the generator-motor to transmit power directly into a ring gear in the vehicle's planetary gear set.”
Now this is just completely wrong. It should say (and herein lies the controversy they refer to): Unlike the other modes, however, this one calls for the internal combustion engine to transmit power directly into a ring gear in the vehicle's planetary gear set.
If you believe the diagrams posted earlier the ICE does not transmit power "directly" into the ring gear but is connected to the motor/generator which in turn is connected to the ring gear. So the ICE, motor/generator and ring gear are connected mechaically as a unit. Then Yes the ICE provides power mechanically to the planetary but thru the motor/generator route.. The question I have and have raised before: does the motor/generator also at this time generate electrical power(from ICE motive power) to drive the large motor? It could very well if the ICE had more power than was required to drive the ring gear at the requested RPM.
It has to, otherwise the 110KW main drive motor has no source of power and it would be a purely ICE driven machine.
How does this explination match-up with this description by GM powertrain engineer Pamela Fletcher? Seems to me the two have some conflicting descriptions.
http://www.youtube.com/watch?v=343-NQKOvLg&feature=related
Appears to me that Pamela's discription is exactly what I stated. The last diagram she shows also shows a transfer of electric power from the generator/motor to the main motor and battery and since the arrows are double ended, back to the motor/generator from the battery. All bases are covered in this arrangement that has all sections of the drive participating at once. And the software is sophisticated enough to operated the crossovers seamlessly. A Marvel!!!
<snip>
Here's a quick look at the four modes:
Electric High-Speed [in Charge-Depleting (CD) mode]: The Volt typically hits this mode at about 70 mph. Then, the supervisory controller splits the power between the large traction motor and a smaller 54-kW generator-motor (which is still operated by the battery). The planetary gear set blends the power from the two motors and sends it to the drive axle.Unlike the other mode, however, this one calls for the generator-motor to transmit power directly into a ring gear in the vehicle's planetary gear set. GM says it has a good reason for doing this - electric motor efficiency typically plummets at higher speeds. "You're bringing down the speed of the main traction motor and supplementing it with the generator-motor," a GM spokesman says. "As a result, you're improving the efficiency Even as it switches to this mode, however, the Volt still isn't employing its internal combustion engine - and therefore still isn't burning any gasoline.
Extended Range Low-Speed [in Charge-Sustaining (CS) mode]: When the battery's charge drops to an unacceptable level, the 1.4 liter I-4 engine (ICE) makes its debut. At normal speeds the engine spins the generator-motor, which provides power for the main drive motor and also replenishes the battery to an acceptable charge level.
Extended Range High-Speed [in Charge-Sustaining (CS) mode]: This is the most complicated and controversial (see sidebar) of the Volt's four modes. With the battery depleted at higher speeds (70+ mph), the controller opts for a power split as in the above high speed (CD) mode, but goes one step further. It calls for the Internal Combustion Engine to be connected to the smaller motor-generator and mechanically provide further power directly to the ring gear in the vehicle's planetary gear set while at the same time generating electric power to drive the main electric motor.>
Sidebar:
Scott2000,
I suggest the drive mode descriptions be edited to something like the above editing I have made.
Super Moderator
Scott2000,I suggest the drive mode descriptions be edited to something like the above editing I have made.
Can you put your edits in [] so I know what changed? It was a little hard to pick up at several glances. I also change the format in my original post to show it is a quote from the article and where I added []'d info.
Basically I just tried to clarify the extended range descriptions to make them more concise
Thread Title said:
Voltec drive unit now has four basic modes of operation ?
ALWAYS DID!
But the one caveat I is the controversial 2 motor combined mode where ICE is contributing torque to the ring gear (though C2 and C3) is only used when torque demand is relatively light at speeds above 36mph. Under high demand it switches to "pure" series 1-motor electric mode with the power demand handled by the 5 5kW generator and RESS "in tandem" and it operates in this fashion all the way up to maximum speed! ;)
WOT
ALWAYS DID!
It's got at least 5 modes, not just the regular 4. It's got reduced power mode, which is a very different driving experience. Or is that just a sub-mode of the CD < 70 MPH mode? I'd say it's different, because of the ICE behavior (ramps in CD < 70 MPH, rails in reduced power).
Possibly 6 - reduced power mode due to engine malfunction (and OOG) is very different than reduced power mode due to depleted battery.
Per Andrew Farah: ... reporting that the magic cutoff speed of 70 mph is what the car uses to determine whether or not to make the engine to partially drive the wheels is incorrect. The engine is used to partially drive the wheels when the car calculates that it will be a more efficient use of the engine's power. There is no hard cutoff point.
http://www.plugincars.com/exclusive...rivetrain-says-volt-electric-vehicle-90758.ht
When the following drive mode begins, does the LCD screen in the VOLT change in any way so you know that it has begun?
Rusty, I was specifically referring to the title of the thread.
"Voltec drive unit now has four basic modes of operation"
...in that the DRIVE UNIT has four basic modes of operation, which is 100% true
If we wanted to diverge into what you are alluding to (software driven "override" modes etc) there are actually several dozen
WOT
I'll grant you that, though it's easy enough in normal operation to hit the other two drive conditions I mentioned.
Well now, doesn't that sound like an interesting challenge! :eek:
But I suspect it'd take a computer diagnostic to detect most of them in action.
Well there is a "plan" currently in early stages of formulation, designed to potentially create a method for gm-volt.com members to arrange temporary access to the hardware and software neccessary to have access to such data, and even record it while for their own research projects!
(perhaps PM George S. Bower for more info)
So Stay Tuned! ;)
In the meantime here is a link to a well written article (written last October after the various Volt technology media "reveals"), with excellent artwork that details these 4 primary modes:
WOT
That could be really exciting!
I did the math and decided that there are at least 36 operating modes for the Volt. There are 6 primary power modalities (CD single, CD blended, CS single, CS blended, reduced power engine available, reduced power no engine), 3 driving styles (normal, sport, and mountain), and two regeneration selections (D and L). For convenience (and because it adds another 18 modes) we won't talk about reverse right now. Neither neutral, though I've noticed the power path indicator shows regeneration during neutral coasting...
So that's 6 x 3 x 2, or 36 differently optimizable software algorithms. For those of you who'd say MM is just like N but with a different SOC - you haven't driven in MM much. MM is really wimpy compared to N.
Question for Volt owners:
When switching in and out of the fourth mode described below (Extended Range High-Speed in Charge-Sustaining (CS) mode), can you feel anything? I can't imagine that it's completely imperceptible.
If I understand your question correctly, going from CD to CS at high speed truly is almost imperceptible, mostly due to road noise hiding any ICE noise. I only notice the switch because of the display change: the battery cartoon fades away, and a gas-pump cartoon zooms into view.
At lower speeds the switch from CD to CS is more noticeable. You actually can hear the engine start, if you know to listen for it. Clearly a bunch of smart code was written to minimize engine noise and make it more-or-less responsive to speed and (in some cases) accelerator position. The ICE does get louder when you "hit the gas."
Chris
1 - 20 of 82 Posts
