1 - 17 of 17 Posts
01A Trim Color Seat - Jet Black
01B Trim Color Seat - LT Neutral
03D Trim Color Seat - Cutgrass / Dark Titanium
03E Trim Color Seat - Ceramic White / Jet Black
03G Trim Color Seat - Jet Black / Dark Titanium
03R Trim Color Seat - Cutgrass / Jet Black
1B0 Trim Color Door Panel Ceramic White MET
1B1 Trim Color Door Panel Frosted Nickel
1CA Trim Color Door Panel Verde
1CB Trim Color Door Panel Pulsar
1CE Trim Color Door Panel - LT Neutral Metallic
1HY Package - Hybrid Option 1
1LS Package - LS Option 1
1LT Package - LT Option 1
1LZ Package - LZ Option 1
1WT Package - WT Option 1
2HY Package - Hybrid Option (2)
2LT Package - LT Option 2
2WT Package - WT Option 2
3HA Package - Hybrid Option (5)
3HB Package - Hybrid Option (3)
3LT Package - LT Option 3
4AW Interior Trim Jet Black / LT Neutral
4B4 Interior Trim Jet Black / Ceramic White
4B5 Interior Trim Jet Black / Dark Titanium / Cutgrass MET
4B6 Interior Trim Jet Black / Dark Titanium / Frosted Nickel
4LT Package - LT Option 4
5A7 Wheel Spare - None
5LT Package - LT Option 5
9L3 Tire Spare - None
A51 Seat FRT BKT, Custom
AL0 Sensor Indicator Inflatable Restraint, FRT PASS / CHILD Presence Detector
ATS Lock Control, Entry - Remote Entry, Standard Range, Passive Entry
AXJ Vehicle Type Passenger Vehicle
AY0 Restraint System Seat, Inflatable, Driver and Passenger Front, Seat Side Roof Side
B37 Covering - Floor Mat, Front and Rear, AUX
B3V Test Extended Water
BTR Identification - Reconciliation
C68 HVAC System - Air Conditioner Front, Auto, Electronic Controls
D30 Color Override Approved Color & Trim Combinations (All Products)
DEH Plant Code Detroit / Hamtramck, MI, USA
DWK Mirror O/S LH and RH, RC, ELEC, Heat, Flat / DRVR, Manfold CNVX / PASS, TRN SIG
EAL Trim Seat Leather, Soleil Keisel, Mini PERF
EEY Trim Seat Cloth, Wired
EF7 Country United States of America (USA)
EPP Identification EPA Mass Certification
EVB PROP ENGY STOR PACK - Propulsion Battery, LI, 370V, 45AH, Underbody T
FE2 Suspension System Ride, Handling
FE9 Certification - Emission, Federal
FHS Vehicle Fuel Gasoline E85
FIF Trim Door Polycarbonate, Film
FIG Trim Door Plastic, Painted
FXW Ratio Transaxle Final Drive 2.16
GAM Vehicle Government (G.S.A. Sales)
GAN Primary Color Exterior, Switchblade Silver Met (G) 636R
GBA Primary Color Exterior, Black (G)
GBE Primary Color - Exterior, Crystal Claret Tintcoat (G) 505Q
GBN Primary Color Exterior, White Diamond Tri-Coat (G) 800J
GBV Primary Color Exterior, Cyber Gray Met (G) 637R
GCN Primary Color Exterior, Victory Red 9260
GLC Primary Color Exterior, Urban Fresh Tri-coat 814T
J60 Brake System - Power, Front and Rear Disc, ABS, 16"
JE0 Brake Electro Hydraulic Apply Front and Rear Electric with Blended Regenerative Braking
KA1 Heater - Seat, Front
KTI Kit, Tire - Inflator
LHD Vehicle Drive Lefthand Drive
LUU Engine - Flexible Fuel, (Gas/Alc), 4 Cyl, 1.4L, MFI, DOHC, E-Flex, FAM 0
MKA Transmission - Automatic, Electronic Ratio Select, GM, Strong Hybrid, EVT, Plug In
N30 Steering Wheel - Deluxe
NB8 Emission Override California System
NE1 Certification - Emission, Geographically Restricted Registration for Vehicles up to 14,000 Lbs, GVW
NK5 Steering Wheel - Standard
NT7 Emission System - Federal, Tier 2
NU5 Emission System - California, Bin 4
PFF Wheel - 17 X 7, Aluminum, Painted
PTT Wheel - 17 X 6.5, Aluminum, Polished
RQ7 Tire All P215/55 R17 SL 93S BW ALS
RSB Wheel - 17 X 7, J, Aluminum, Design 1
RTN Wheel - 17 X 7, J, Aluminum, Design 2
T1G Vehicle Military Personnel Delivery
U2J Digital Audio System S-Band "Not Installed"
U2K Digital Audio System - S-Band
UD5 Sensor Indicator Parking Assist
UE1 Communication System - Vehicle, G.P.S. 1
UEX Communication EQUIP Remote Data Transfer
UFU Radio AM/FM Stereo, Single CD, MP3 (AUX IN), USB
UFV Radio AM/FM, DVD ROM & HDD, MP3 (AUX IN), USB, NAV
UG1 Opener Garage Door, Universal
UJM Tire Press Indicator Manual Learn
UPF Wireless Interface - Short Range, Voice REC
UQA Speaker System Premium Audio Branded with Amplifier
UVC Camera Rear View
UZ6 Speaker System 6, Premium
V8D Vehicle Statement US
VK3 License Plate Front - Front Mounting Pkg
VRG Value Added ASM - Cockpit
VRJ Value Added ASM - Powertrain Dress
VRH Value Added ASM - Steering Column
VRK Value Added ASM - Roof Trim
VRL Value Added ASM - Front Horizontal Suspension
VRM Value Added ASM - Front Vertical Suspension
VRN Value Added ASM - Rear Suspension
VRR Value Added ASM - Tires & Wheels
VT7 Owners Manual English Language
VZ3 Label Mercury Disposal Notification
WT9 Order Modification NAES for Domestic Delivery
YE8 Vehicle Test, Engineering
YF5 Certification - Emission, California
ZR6 Show Vehicle Zone
ZV1 Statement of Origin Manufacture
Emmissions
Wow, you really have to build to 4 separate emissions standards in the US?!? (FE9, NE1, NB8, NB9).
Wouldn't it be less expensive, due to economies of scale, to simply build to the most stringent standard?
Sorry, that's the Program Manager in me leaking out.
I hear ya!
In reality though this isnt so unusual.
Most "overrides" are nothing more than a different underhood emissions label required for state compliance and in the case of California or CARB states, possibly a slightly different powertrain/engine control module calibration. Generally there are no hardware differences just software. Remember changing calibrations to optimize combustion stoichiometry for emissions in a specific point of a state enforced test cycle will generally come with some sort of sacrifice- often in mpg or general drivability. Why make other states suffer?
WOT
Great info, thanks WOT!!!
One question ... The vat majority of these are not "options" exactly, coming standard with the car. Could this be an advance sign of the features that they might consider making optional in future model years? That is, loading the car up for this launch model year only.
Personally, I'd be interested in swapping out the LUU option :)
"Personally, I'd be interested in swapping out the LUU option "
You and lots of other people.. the Volt would get pretty peppy if it suddenly lost 400lbs of genset and even more if it had been designed from scratch for that.
I actually meant swapping it out for other genset technologies, like Wankel, opposing cylinder, fuel cell, etc., all the things that you all have been discussing here.
No doubt, electrification of the drivetrain opens up all of those possibilities.
Discussion Starter · #7 ·
One question ... The vat majority of these are not "options" exactly, coming standard with the car. Could this be an advance sign of the features that they might consider making optional in future model years? That is, loading the car up for this launch model year only?
No not at all. As you can see almost ANYTHING that goes into a car's construction has an RPO code. Determining which are "standard" equipment and which are truely "optional" can only be deciphered using the appropriate Vehicle Order Guide (or perhaps online order tools/applications like those found on the chevrolet.com website)
HTH
WOT
I hear ya!
Most "overrides" are nothing more than a different underhood emissions label required for state compliance and in the case of California or CARB states, possibly a slightly different powertrain/engine control module calibration. Generally there are no hardware differences just software. Remember changing calibrations to optimize combustion stoichiometry for emissions in a specific point of a state enforced test cycle will generall come with some sacrifice- often in mpg or general drivability. Why make other states suffer?
WOT
I guess I shouldn't be surprised--given the fact that metropolitan areas can mandate their own boutique gasoline formulas. Oxygenated gasoline...don't get me started, especially when all modern cars have O2 sensors that control/optimize the mixture.
I heard that the premium cloth is like vinyl with a cloth insert in the middle. Is that true?
Discussion Starter · #11 ·
I can't tell if that's vinyl or what on the seats with premium cloth.
The premium cloth seating is all cloth.
Thanks!
Angie - Chevrolet Volt Advisor
[email protected]
As of Aug 31 2010:
A51 Seats, front bucket
AY0 Air bags, dual-stage frontal, side-impact and knee for driver and front passenger androof-rail side-impact for front and rear outboard seating positions
C68 Air conditioning, single-zone automatic climate control
DWK Mirrors, outside heated power-adjustable, body-color
EAL Seat trim, perforated leather-appointed
EEY Seat trim, Premium Cloth
EVB Battery, Propulsion, Lithium-ion (16-kWh)
FE9 Emissions, Federal requirements
FIF Door trim, premium
J60 Brakes, 4-wheel antilock, 4-wheel disc
KA1 Seats, heated driver and front passenger
KTI Tire inflation kit
LUU Engine, Range Extender, 1.4L Internal Combustion Engine
MKA Electric drive unit, Voltec
N30 Steering wheel, leather-wrapped
NB8 Emissions override, California
NB9 Emissions override, state-specific
NC7 Emissions override, Federal
NE1 Emissions, Connecticut, Maine, Maryland, Massachusetts, New Jersey, New Mexico, New York, Oregon, Pennsylvania, Rhode Island, Vermont and Washington state requirements
NK5 Steering wheel
PCQ Premium Trim Package
PCW Rear Camera and Park Assist Package
RBB Tires, P215/55R17 all-season, blackwall
RSB Wheels, 17" (43.2 cm) 5-spoke forged painted aluminum
RTN Wheels, 17" (43.2 cm) 5-spoke forged polished aluminum
U2K XM Radio
UD5 Parking assist, front and rear
UE1 OnStar, 5 years of Directions and Connections plan
UFV Audio system with navigation, AM/FM stereo with DVD-ROM and MP3 playback capability
UG1 Universal Home Remote
UJM Tire Pressure Monitor System
UPF Bluetooth for phone, personal cell phone connectivity to vehicle audio system
UQA Audio system feature, Bose premium speaker system
UVC Rearview camera system
VK3 License plate bracket, front
YF5 Emissions, California state requirements
WOT: The upgraded www.camarotracking.com site now shows fairly detailed info about your order. My order is copied below. Note that there are a number of codes not listed above:
Options and Accessories
*Please Note: content shown may not include all your options and accessories. See dealer for complete list.
•U2K XM Radio
Radio
•UFV Audio System With Navigation
Sales Processing
•SLL Sold Order Processing Code
Steering Wheel
•NK5 STEERING WHEEL STANDARD
Engine
•LUU Range Extender. 1.4L Internal Combustion Engine
Primary Color
•GBE Crystal Red Metallic Tintcoat
Suspension System
•FE2 SUSPENSION SYSTEM RIDE, HANDLING
Trim Seat
•EEY TRIM SEAT CLOTH, WIRED
Miscelanious Details
•1SZ Discount Option Package
•UVC Rearview Camera System
•UD5 Park Assist, Front And Rear, Ultrasonic
•R9Z CONTROL SALES ITEM NO.100
•R9N CONTROL SALES ITEM NO. 89
•R6J CONTROL SALES ITEM NO. 10
•PCW Rear Camera And Park Assist
•E2C Processing Code, OTD Expedite
Speaker System
•UQA Bose Premium Speaker System
•UE1 OnStar
Wheel
•RSB Wheels, 17" 5-spoke Forged Painted Aluminum
Transmission
•MKA Electric Drive Unit, 16 KWh Lithium-ion Battery
Brake System
•J60 BRAKE SYSTEM POWER, FRT & RR DISC, ABS, 16"
Certification
•FE9 Emissions, Federal Requirements
Country
•EF7 US Country Code
Interior Trim Config
•AFA Jet Black Cloth Interior/Black Accents
Really, JohnK? Posting the exact same thing in three different threads? It's informative, but ...
Does anyone know the Li-ion Propulsion Battery Pack RPO code for the 2013 model? It was "EVB" for 2011-2012 models. However, I assume the code changed for the newly improved 16.5kWh version of the battery.
Btw, according to the "EVB" RPO description, i.e. 370V - 45Ah, the theoretical maximum capacity rating should be 16.65kWh, not 16.0kWh. Interesting!
Discussion Starter · #17 ·
still EVB for 2013
These are `marketing- sales`specs not engineering specs, so they must be taken with a grain of salt...
WOT
PS - I`ll try to update this thread with the 2013 RPOs later this week
1 - 17 of 17 Posts
