Hi all,
I am interested in purchasing a used volt, but I currently go to college in Grand Forks, North Dakota where the temperature is routinely below 0F. I read somewhere that the Volt battery electrolyte will freeze at -13F. Is this true? I found some videos and information online about the volt starting in at -47F, however all the videos I have seen of cold starting has been with the car plugged in, and I was wondering if the Volt will still start and run at cold temperatures without being plugged. For the next 3 months, I will be unable to plug in as the parking lot for freshmen students in the mandatory dorms does not have outlets, but at home this summer and our house next year I will be able to charge. Would it help to put the Volt into Mountain mode to hold a higher state of charge and possibly have more voltage/power to crank the engine in colder temperatures? Also, how quickly does the Volt warm the cabin after being remote preconditioned (I.E. at extreme cold temperatures how many times should I use the remote to start the car to achieve a comfortable temperature?). Thanks for the advice!!
