So, with the holiday season around the corner, I'll be putting up a good deal of lights on the front of the house this week. I only have one outlet there, which I use to charge my Volt. I can typically get by with 8 amp charging given a relatively short work commute.
I honestly don't know the kind of wiring used on the outlet or the breaker or anything like that, which I guess is really important. My guess is since the outlet is on a relatively recently converted garage, the wiring is at least copper and up to code. Question is, can I attach three or so strands of light via a surge protector on the bottom outlet and continue to use the top outlet to charge at 8 amps, or is this likely to trip the breaker and/or damage the outlet/wiring/EVSE.
I understand I'm giving you not nearly enough information to answer this question. I guess the question is -- standard wiring, standard outlet, can it support Volt and lights.
