Thanks.. But that stinks and that should be an easy software fix. I unplug several times up here and that really is easy to forget.
Obviously they still have issues with these cords. The 2011 had one replaced because first one burt out.
You would think this problem was solved in 2 years.
Some of us (probably a minority!) are in the other camp, thinking this was a good idea from a safety and heat stand point, and perhaps even better for "the grid" as well as extending the life of your charge connector (EVSE).
Consider if overnight 8 amp charging can actually fit fine your lifestyle. You might be surprised to find it does. It does for me, and I put a fair number of miles on my Volt (26k EV miles in a year and 3 months)
For example, I have a 2012 and was charging over night at 12 amps for almost a year. FYI, my commute ~35 miles each way, so get home usually ~6:30 pm and plug in with typically ~10-15 miles range remaining. Besides finishing excessively early (often ~1 am) I found that the EVSE and its cable would get quite warm.
Now charging at 8 amps almost every night (unless I get home REALLY late at night) the charging is done still plenty early (~3:30 am) and much less heat is generated (wasted?).
This probably won't help you if you are fully depleting your Volt's battery before returning home every day; but otherwise I would encourage even '11 and '12 owners to make 8 amp charging overnight the rule and 12 amp the exception or for daytime opportunity charges with known good/robust outlets. Making this change might mean very few setting changes needed.
