1 - 20 of 36 Posts
Hey everyone just trying to spot any potential good deals on Volts in Michigan to lease at prices under $250 a month. I hate that we can't go to other states to pick up a lease and bring it back or I would be driving to go get one for cheaper.
A few deals I'm seeing is around $300 for these and that's not where I want to be at
I'm looking for entry level Volt with heated seats I'd love to get my hands on the premier but I don't believe an extra $5k is worth it for everything on the car.
And yes I traded my 14 Volt in for a Challenger and I do regret it but when the new V2 came out for the Volt the prices were just AWFUL I couldn't afford it.. I pay right now $250 monthly fully loaded Challenger when I was looking for Volts-V2 they were entry level $270+plus a large down payment didn't make any sense of doing the lease.
Thank you kindly
Static websites are not the best - especially if you are a web forum.
· Administrator
You successfully interpreted the new, tongue-in-cheek title I added to this thread. :)
Actually this video seems more appropriate
Or this time traveling fav
Or this one
And where this all started
Can’t forget hot tub time machine
And interstellar
Then there’s Kate & Leopoldo, FTW
· Administrator
Static Movement Vs. Impact:
It's just trance..... with a static background.
Like The Blair Witch Project, I kept watching expecting that something would actually happen... lol
And so my "ad nauseum jokes" that don't add value aren't seen as my only contribution, some philosophy:
Parmenides held that the multiplicity of existing things, their changing forms and motion, are but an appearance of a single eternal reality (“Being”), thus giving rise to the Parmenidean principle that “all is one.” From this concept of Being, he went on to say that all claims of change or of non-Being are illogical.
Eleaticism, one of the principal schools of ancient pre-Socratic philosophy, so called from its seat in the Greek colony of Elea (or Velia) in southern Italy. This school, which flourished in the 5th century BCE, was distinguished by its radical monism—i.e., its doctrine of the One, according to which all that exists (or is really true) is a static plenum of Being as such, and nothing exists that stands either in contrast or in contradiction to Being. Thus, all differentiation, motion, and change must be illusory. This monism is also reflected in its view that existence, thought, and expression coalesce into one.
Static field variable initializers and static constructors:
The static field variable initializers of a class correspond to a sequence of assignments that are executed in the textual order in which they appear in the class declaration. If a static constructor (§10.12) exists in the class, execution of the static field initializers occurs immediately prior to executing that static constructor. Otherwise, the static field initializers are executed at an implementation-dependent time prior to the first use of a static field of that class.
I believe the guidance in your second line is actually to initialize static fields that are not done inline, using field initializers. In that case, you should use a static constructor to guarantee that they will be initialized prior to usage.
As you can see from the specification, the actual "time" they come into existence is implementation specific, and subject to change. The only guarantee is that they will exist prior to the static constructor being called, which will always occur prior to their usage in code. This specification states (in 10.12):
The execution of a static constructor is triggered by the first of the following events to occur within an application domain:
· An instance of the class type is created.
· Any of the static members of the class type are referenced.
tl/dr:
Static fields are guaranteed to be initialized prior to the first use of the class.
Optionally, you can provide a static constructor to control static initialization at the time it occurs.
No power in the ‘verse can stop me.... River Tam
1 - 20 of 36 Posts
