1 - 6 of 6 Posts
Hello volt forums
I'm trying to find a list of useful PIDs and commands to issue through OBD2 so I can do analytics and automation and learn python and stuff.
I have the google sheets list of all PIDs that the community compiled (https://docs.google.com/spreadsheets/d/1HgWCnosdRqZYoWHEl7ylAxjxv4UFVeisWiR7gcr8H6I/edit#gid=0), but a lot of them are unclear to me.
So far: Fuel Level, Fuel Remaining, SOC, Speed, chargewatt, and lastcharge Wh seem to be the most useful ones.
Are there commands for controlling the windows or for starting/shutting down the car or for the media center? Or would I have to go CAN sniffing to find that out, if it's possible at all?
Thanks!
here some that i find useful : most of them are meant for gas driven cars but some cross work. rest just ignore em.
Name ShortName ModeAndPID Equation Min Value Max Value Units OBD Header
Control Module Voltage Cont. Mod. Volt 220042 (A*256+B)/1000 0 15 V 7.00E+00
Engine Coolant Temp Coolant Temp 220005 (A-40) -40 200 C 7.00E+00
Engine Oil Temp Oil Temp 221154 (A-40) -40 200 C 7.00E+00
Fuel Level Fuel Level 22002F A*100/255 0 100 % 7.00E+00
Fuel Remaining Fuel Remaining 22002F (A/255)*9.3122 0 9.3 Gallons 7.00E+00
Hybrid Pack Remaining (SOC) SOC 22005B A*100/255 0 100 % 7.00E+00
Speed kmh Speed 22000D A 0 200 kmh 7.00E+00
*M Commanded Throttle Pos Commanded Throttle Pos 22004C A*100/255 0 100 % 7.00E+00
*M Engine Torque Engine Torque 22203F ((256*A)+B)/4 0 200 Nm 7.00E+00
*M Fuel System Status M11 31 B1 221131 A 0 255 B1 7.00E+00
*M Intake Air Temp IAT IAT 22000F (A-40)/2 -20 100 C 7.00E+00
*M Long Term Fuel Trip Bank 2 M15 73 B1 221573 100*A/255 0 100 % 7.00E+00
*M Long Term Fuel Trip Bank1 M15 72 B1 221572 100*A/255 0 100 % 7.00E+00
*M Short Term Fuel Trip Bank1 M15 70 B1 22 15 70 100*A/255 0 100 % 7.00E+00
*M Short Term Fuel Trip Bank2 M15 71 B1 221571 100*A/255 0 100 % 7.00E+00
*M Spark Advance Spark Advance 22000E A/2-64 -64 64 Deg 7.00E+00
mileage Engine RPM 22000C (A*256+B)/4 0 8192 rpm 7.00E+00
HV Discharge Amps HV Amps 222414 (S_A*256+B)/20 -100 100 A 7.00E+01
MGA Voltage MGA V 222885 (A*256+B)/100 0 400 V 7.00E+01
MGB Voltage MGB V 222886 (A*256+B)/100 0 400 V 7.00E+01
PRNDL PRNDL 222889 A 0 8 7.00E+01
Transmission Pressure Trans Pressure 222862 (S_A*256+B) 0 20000 7.00E+01
BRAKE H1 24 34 222434 (A*256+B)/64 0 420 V 7.00E+01
Tran Temp Tran Temp 221940 (A-40) -40 215 C 7.00E+02
Clutch Slip C1 (Ring) C1(Ring) Slip 222851 (S_A*256+B)/4 -8192 8192 RPM 7.00E+02
TCM 19 9E 1byte T 19 9E 1b 22199E (S_A*256+B) -32000 32000 V 7.00E+02
TCM 1A 18 T 1A 18 1b 221A18 (S_A*256+B) -32000 32000 V 7.00E+02
TCM 1A 1F T 1A 1F 1b 221A1F (S_A*256+B) -32000 32000 V 7.00E+02
TCM 28 54 T 28 54 1b 222854 (S_A*256+B) -32000 32000 V 7.00E+02
Clutch C2 Slip C2 Slip 222853 (S_A*256+B)/4 -8192 8192 RPM 7.00E+02
Clutch C3 Slip C3 Slip 2219D4 (S_A*256+B)/4 -8192 8192 RPM 7.00E+02
Transmission ISS 19 41 Tran ISS 221941 ((S_A*256+B))/4 -32000 32000 RPM 7.00E+02
Charger AC Current ChargerAmpsIn 224369 A*0.2 0 50 A 7.00E+04
Charger AC Voltage ChargerVoltsIn 224368 A*2 0 512 V 7.00E+04
Charger HV Current ChargeAmp 22436C ((S_A*256+B))/20 0 20 A 7.00E+04
Charger HV Power ChargeWatt 224373 (S_A*256+B) 0 3000 W 7.00E+04
Charger HV Voltage ChargeVolt 43 6B 22436B ((S_A*256+B))/2 0 400 V 7.00E+04
HV Battery Temp Bat Temp 22434F (A-40) -20 100 C 7.00E+04
Last Charge AC Wh LastCharge Wh 22437D ((A*256+B))*10 0 20000 Wh 7.00E+04
Power Electronics Cooling Temp Ele.Temp 221C43 (A-40) -20 100 C 7.00E+04
Onboard LVolt Charg V LV Charge V 224374 (S_A*256+B) -32000 32000 V 7.00E+04
H2 Amp from VICM H2 43 56 224356 (S_A*256+B)/20 -100 100 A 7.00E+04
Bat Coolant Pump RPM CoolPumpRpm 2241B2 (S_A*256+B) 0 5000 RPM 7.00E+04
Bat Coolant Valve CoolValve 2241B4 (A) 0 255 ? 7.00E+04
Bat heat Bat Heat 2241B6 (S_A*256+B) 0 5000 W 7.00E+04
Charging Limit? H2 41 B7 2241B7 (S_A*256+B) 0 32000 W 7.00E+04
H2 Volt from VICM? H2 43 2D 22432D (S_A*256+B)/2 0 400 V 7.00E+04
M AC High Side Preassure M15 64 B1 221564 A 0 255 kPa 7.00E+04
Outside Temp Filtered OAT Raw 22801E ((A-40)/8) -20 50 C 7.00E+04
LV Charge Amps 43 7E 22437E (S_A*256+B)/20 -100 100 A 7.00E+04
*M Engine Torque m1 Engine Torque m1 163 ((256*A)+B) 0 2000 Nm
Barometric Pressure BARO 2102 H/255*119 0 119 kPa
Coltage Coolant Temperature VoltECT 2101 (A*256+B)/205 0 5 V
Coolant Temperature ЕСТ 2102 A/255*192-49 -50 140 C
Correction of injection time CorrInj 2102 (T*256+U)/250 0 65535 ms
Desired Idle NeedIdleRPM 210d M*256+N 500 1500 rpm
Desired Ignition timing DesIT 2103 (G-64)/2.677 -30 72 deg
Evoparator Duty Cycle Blow Evo 2102 X/255*100 0 100 %
Exhaust Gas Recirculation Flow EGR 2102 Y/255*100 0 100 %
FL Wheel Speed FLSpeed 210b AA 0 255 km/h
Fuel level FuelAvg 210b X/4 0 60 L
Ignition timing Cyl1 IT1 2103 (192-A)/2.677 -30 72 deg
Ignition timing Cyl2 IT2 2103 (192-B)/2.677 -30 72 deg
Ignition timing Cyl3 IT3 2103 (192-C)/2.677 -30 72 deg
Ignition timing Cyl4 IT4 2103 (192-D)/2.677 -30 72 deg
Injection duration current InjDur 2102 (P*256+Q)/250 0 0 ms
Injection duration on start InjDurSt 2102 (N*256+O)/62.5 0 1050 ms
Instant Fuel Level FuelCur 2102 Z/255*45 0 45 l
Instant Fuel Percent Fuel% 2102 Z/255*100 0 100 %
Intake Air Temperature IAT 2102 B/255*192-49 -50 140 C
Manifold Absolute Pressure МАР 2102 J/255*119 0 119 kPa
Mass Airflow MAF 2102 (L*256+M)/47 0 1400 mg/t
Real Throttle Position RealTPS 2102 AC 0 255 steps
Signal Throtle Position SignalTPS 2106 C/255*100 0 100 %
Throttle Position TPS 2102 C/255*100 0 100 %
Time from the start engine EngRunTime 2117 (I*256+J)/10 0 6553.5 sec
Voltage Air Conditioner Refrigerant Pressure VoltACRP 2101 (AC*256+AD)/205 0 0 V
Voltage Fueal Gauge Sending Unit VoltFGSU 2101 (AA*256+AB)/205 0 12 V
Voltage Fuel Level VoltFuel 2102 Z/255*5 0 5 V
Voltage Idle Air Control VoltIAC 2101 (E*256+F)/205 0 5 V
Voltage Intake Air Temperature VoltIAT 2101 (C*256+D)/205 0 0 V
Voltage Knock Sensor KnockSens 2101 (G*256+H)/205 0 0 V
Voltage O2 Sensor1 O2S1 2104 (C*256+B)*4.88 0 319810 mV
Voltage O2 Sensor2 O2S2 2104 (G*256+F)*4.88 0 319810 mV
Voltage Volt 2102 D/8.88 0 16 V
Name ShortName ModeAndPID Equation Min Value Max Value Units Header
AC Hi Side Pressure -F AC Pres 221144 A/51 0 5 Volts
AC Hi Side Pressure2 -F AC Pres 221144 (A*1.83)-15 0 400 "PSI"
hi,
obxMX owner here, I was thinking to buy an addon on software(as app detected my 2015 Volt and suggested to get additional suitable pids for it. it asked for 10$, I'm currently unable to buy as I live in Tbilisi/Georgia. maybe I can grub all those PID IDs from program and share it later.
2019 Chevrolet Volt
Hello volt forums
I have the google sheets list of all PIDs that the community compiled (Volt PIDs), but a lot of them are unclear to me.
For more information about tuners and programmers please visit the website here www.jeepzine.com/best-tuners-and-programmers-for-jeep/
Thanks!
How do I know if my vehicle is obd2 compliant?
it has a obd2 plug in the driver's side footwell or are you asking if it will pass obd2 check?passes if theres no check engine light on.
1 - 6 of 6 Posts
