Since I bought my 2013 (two years ago) I’ve used the same USB stick which contained all my music. A few times I’ve re-synced the stick with my PC as I’ve updated my collection. I use Windows Media Player 12 (Win 10) to transfer the music files and SyncPlaylist to sync the playlists (playlists are created and managed with WMP). Everything has worked fine, but I’ve never really liked the way SyncPlaylist creates additional copies of the files on the USB. It works fine when listening to the playlist but if you listen to the album you end up having multiple copies of the song on the album, e.g., if “I Walk the Line” is on three different playlists when you play Johnny Cash’s Greatest Hits you’ll hear “Walk the Line” four times in a row.
Doing a bit of internet digging I found a way of formatting/editing the playlists manually (text editor) and manually copying to the USB. Supposedly worked with a FordSync radio. Saturday night I took a BRAND NEW USB stick, transferred the music via WMP and the playlists manually. Went out to the garage, turned on the radio in accessory mode (which may have been the problem right there) and put in the USB. First song on the stick started playing and display showed the song info and “indexing…” - everything looked normal. I knew it would take awhile to index 1000 songs so I went inside to watch some youtube. When I came out later everything was off. Looked like accessory mode had shutdown. I re-started and the display immediately showed “indexing…” OK - maybe it didn’t finish. Powered the car fully on and left it to index. Came back everything seemed good - music playing, display on. Then I realized the song on the display wasn’t the song playing and the display was frozen - the time bar for the song wasn’t moving - I watched it for a full 30 seconds to make sure. Powered everything down and tried again, same result. At that point changing the source flips it back to Sirius - hitting the source button to get to USB gets a momentary change to the USB source and then it flips right back to Sirius. Multiple “sources” gets the radio to the AM and FM sources. I then inserted my old USB - which had worked perfectly earlier that day. Same thing happened - stuck at indexing with a frozen screen. The next day we had to take a small road trip (hour each way) and I tried my wife’s USB - which, again had been working perfectly fine a few days earlier. Radio and bluetooth seem to work fine, just the USB is messed up. When we got home I disconnected the -12v lead at the battery hoping to reset something that might have gotten "stuck" in software. Today she reported the same behaviour. I pulled the -12v lead again and left it off for 10 minutes. (Both times the clock reset to 12:00 but the radio presets stayed where I had set them.) No joy. Pulled the F2 fuse for the radio. I know it wouldn’t do anything more than disconnecting the battery but it’s simple and easy - so why not? No luck. I reformatted and re-synced the new USB using SyncPlaylist and tried again. No change.
At this point, while the music does play there is basically no control. With the screen frozen and “indexing” the menu button is non-responsive. Changing the USB gets into the flip back to Sirius mode - basically the system doesn’t recognize the USB. A totally power down of the car seems to be the only way to get the USB to read and then it’s back to the frozen screen.
Any thoughts? Or have I manged to somehow completely bugger the USB system?
