Proud new Volt owner. Charging at 120v just wasn't going to do. I started by installing a NEMA 14-30 outlet in my garage and building an adapter to run the stock Volt EVSE at 240v and was happy with that for about a week.
So I started looking on eBay for L2 EVSEs and with a bit of patience picked up a ClipperCreek LCS-25 with an L6-30 plug for a decent price. I didn't want to switch to an L6-30 wall receptacle since the L6-30 plug would then be sticking straight out of the wall (it's not a 90-degree plug), so instead I built a 14-30 plug to L6-30 receptacle adapter cable. As long as I was doing that, I added a multimeter to the mix so I could keep track of what portion of my electric bill was going to the Volt. So the parts were:
Here's my new charging station:
I guess I can thank the 248v on Shearon Harris plant being about 6 miles away. So I seem to get around 3.9 KW at 16 amps current. I̵ ̵h̵a̵v̵e̵n̵'̵t̵ ̵c̵h̵a̵r̵g̵e̵d̵ ̵f̵r̵o̵m̵ ̵0̵ ̵m̵i̵l̵e̵s̵ ̵E̵V̵ ̵r̵a̵n̵g̵e̵ ̵y̵e̵t̵ ̵b̵u̵t̵ ̵I̵ ̵e̵x̵p̵e̵c̵t̵ ̵i̵t̵ ̵t̵o̵ ̵b̵e̵ ̵a̵ ̵b̵i̵t̵ ̵o̵v̵e̵r̵ ̵4̵ ̵h̵o̵u̵r̵s̵.̵ 4 hours 10 minutes to fully charge from empty, and around 17 KWH.
- 4' dryer cord with a 14-30 plug
- L6-30 receptacle
- "bayite AC 80-260V 100A BAYITE-PZEM-061 LCD Display Digital Current Voltage Power Energy Multimeter Ammeter Voltmeter with Current Transformer CT"
- 2 gang gray PVC electrical box and cover
