I have had my 2013 Volt for 5 years and have seen pretty steady range results with the usual seasonal oscillations. Generally my warm weather, real world AER is between 38 and 44 miles (GoM usually a mile or two more) depending on weather, amount of passengers, AC use and type of driving. But over 4 summers, it has been pretty steady. Up until April, everything looked the same, I started to get my warm weather increase on both the GoM and in real world range. Then in late April/early May I noticed that my range had dropped off and was 31-36 miles, not 38-44. My morning drive to work is short but it went from 0.7-0.8 to 0.8-0.9. Almost too short to be useful, but consistent with my other range loss numbers. The amount of gear I carry has stayed the same, my driving pattern is the same, my AC use is the same. I recently got the oil changed, which shouldn't matter but it didn't change anything with regards to range, so no surprise there. 2 of my tires are nearing end of life with 6/32 of tread left, but they were balanced and rotated just 8,000 miles ago when I got 2 new tires.
I have tried braking hard to re-set the brakes in case a caliper was dragging, but I don't have a lift to check and see if the tires are rotating without dragging.
Any suggestions on what I should check before I take it to the service department for my 5 year coolant replacement? I will probably replace the 2 older tires at that time, but new tires usually drop range, not increase it, at least for the first thousand miles or so.
I doubt that battery age would manifest itself over a time frame as short as 2 months, but I can't figure out what I am missing. Any suggestions would be greatly appreciated!
