1 - 4 of 4 Posts
I had set the home location on my 16 to the 12 amp 120 V charging option as default. It's worked fine that way unbroken for 7 months, but this morning just after plugging it in when it was slowly charging I realized that the car had reset itself to the 8 amp default. Anybody run into this before? I reset it of course to 12.
Thanks
I have 2013 Volts, but I seem to remember a post that the Gen 2 resets after a certain period of time. You may want to check the manual.
Program charge will go back to default settings after a preset time.
YES, check the manual. If I recall, it is only holding that program for a designated amount of time then i resets back to default..
Discussion Starter #4
You are both correct. Has to be reset every 90 days in terms of location charging preference. The odd thing is I've had the car for almost 7 months and never had to do it before.
1 - 4 of 4 Posts
