Good news!This looks like what we've all been waiting for... Would love to know more about cost and labor.
Yes. Mixing modules from different years was not an option before. That's a pretty significant change.The way this reads is that the P1.7 packs (all three sections) can be used on all years of first gen Volts and. ELRs. Nothing more. Unless I'm mistaken in my understanding
Nice find, thanks for posting MrSnuzzy336.
The TSB is dated March 2022, applies to North American 2011-2015 Volts, 201402016 ELR's .
Subject: Information on High Voltage Battery Pack Refurbish Kit
Note: All usage for the pack requires TAC authorization.
A lower cost, high voltage battery pack refurbish kit is now available when the battery pack assembly needs to be replaced for certain repairs where cell replacement is needed.
– This refurbish kit includes a combination of 3 refurbished or new P1.7 lithium sections. This refurbish kit can be used in place of a full (New) P1.4, P1.5, or P1.7 pack or when asection is unavailable.
Note: For 2011-2012 models (without RPO YK8), the HPCM2 will need to be reprogrammed to support the P1.7 pack. TAC will contact Techline to have the calibrations ported over for that VIN.
Note: The Battery Service Center (BSC) will provide 3 best available sections to match the vehicles capacity at time of order. Pricing can vary daily for customer pay situations based on inventory at time of quote.
⇒ The GM Technical Assistance Center (TAC) must be contacted to authorize a refurbish kit. Please review Service Bulletin 19-NA-214 for information required. Once TAC gives the authorization, U.S. dealers should contact the GM Battery Service Center (BSC) at 1-833-334-6272. In Canada, TAC will order the Drive Motor Battery Pack through York Electronics in Oshawa
The big unknown is how much a dealer would charge to replace one, two, or all three Sections depending on the Volt's battery issue. We've seen quotes as high as $23k or so, whether that's based on this TSB or not, unknown.
The Takeaway: An entire battery pack swap is not needed. GM Dealers will be able to replace a single section of the three section battery pack and they will be able to do it without regard to matching the existing battery chemistry . A 2011 Volt could use a 2015 Section.
