2014 Volt 44.5K miles
I'm terrible at identifying suspension parts and some of the suspension is under warranty, others are not.
This is left rear wheel. The part has disconnected
So what's the name of the part? Do you happen to know if it's covered under warranty?
I think this is relevant part of the warranty
Drive Systems
Drive system coverage includes all internally lubricated parts, final drive housings, axle shafts and bearings, constant velocity joints, propeller shafts and universal joints. All mounts, supports, seals, and gaskets, as well as any electrical components internal to the drive axle. Also covered are any actuators directly connected to the drive axle (e.g., front differential actuator). Exclusions: Excluded from the powertrain coverage are all wheel bearings, drive wheel front and rear hub bearings, locking hubs, drive system cooling, lines, hoses, radiator, sensors, wiring, and electrical connectors related to drive systems, as well as any drive system control module and/or module programming.
Drive Systems
