Just wanted to share this story in case anyone else is wondering. I admit, it was my fault, but
I stopped to get gas and press the button to depressurize the gas tank. I removed the gas tank cap and proceeded to put my credit card in the gas pump and gas up. I was unable to gas up because the store was changing shifts and had the all pumps turned off. Being impatient and lazy, I simply got in my car and drove to the station next door without putting the gas cap back on or shutting the gas lid. When I got to the station next door, I did not push the gas tank release button because I did not put the gas cap back on or close the gas door. I did the payment thing and inserted the gas pump nozzle in the gas tank. Every time I squeezed the gas pump handle, the gas pump handle would cut off as though my tank was full. At first I though maybe I was pumping too fast, but no it continued to cut off regardless of how slow I pumped. I finally realized that even though I did not put the gas cap back on and shut the door, I still had to push the gas tank release button again. I pressed the gas tank release button and everything was fine and I filled up. Apparently there must be another valve that allows the gas to flow from the gas tanks' input nozzle to the tank itself and turning your car on closes it regardless of whether your put the gas cap on or not. I though the gas cap held the pressure, but apparently not.
So I guess the conclusion is, if you turn you car on, the gas tank pressurizes whether you put the gas cap back on or not and you must depressurize again if you want to put gas in the car.
Anyway, just thought I would share this 'duh' moment. Please correct me if I am incorrect.
