Hope the Volt doesn't run into this problem.
Hope the Volt doesn't run into this problem.The automaker is recalling Prius vehicles from 2010 to 2014 to update the software. The settings "could result in higher thermal stress in certain transistors," which would be flagged by warning lights, the company said.
"In rare circumstances, the hybrid system might shut down while the vehicle is being driven, resulting in the loss of power and the vehicle coming to a stop," said Toyota, in a press release.
The Volt has liquid cooled power electronics, which would cover this problem, I assume. If the Prius doesn't, they may have to change the software to provide less electric power under some circumstances.How the Volt doesn't run into this problem.
there are only 50,000 volts out there- All the power electronics are liquid cooled. That doesn't mean there won't be recalls, but if something is going to happen only once in 200,000 cars, then there aren't any volts out there yet with that isssue, where there would be 10 toyota hybrids....How the Volt doesn't run into this problem.
