Toyota introduces advanced FCV.
21521 Views 86 Replies 20 Participants Last post by  MarcDannenberg
Toyota introduces advanced FCV:
Link
Please forgive the author's ignorance of hybrid vehicles. The author tries to compare a parallel hybrid to a fuel cell vehicle, and totally botches it. It's best to stick to the first couple paragraphs.
The race for fuel cell vehicles is on.
41 - 60 of 87 Posts
Even though I also feel that the BEV will beat the pants off of the hydrogen car I think hydrogen research and development should continue. It has been argued extensively in the past that hydrogen may be the only alternative for some niche markets. However, The focus should be on exactly what Koz just posted, "advancement of batteries, electric drivetrain components, range extending power generation, AND charging infrastructure. " BEVs and plug-in hybrids will get us where we need to be - independence from petroleum imports. I don't know what the exact economic ramifications will be but what we are doing now is killing us with a slow bleed. A Band-Aid is not going to do it. We need to stitch that up (or should I say sew that limb back on).
Texas,
Expanding on your analogy, BEV's are one stitch, REEV's are another stitch, ethanol vehicles are another stitch, high mileage ICE vehicles are another stitch, conservation is another stitch ....
It's going to take all those things to address all the niche markets out there for automobiles.
Rough numbers: The cost of fuel cells have come down. Say a fuel cell costs $3000 and outputs 16 kW. Compare this with a GM 455 325 hp engine, costing $2100. Then the relative cost per kW is a factor of 21. Not exact, but it certainly establish the point that fuel cells, per kW, are more than an order of magnitude more expensive. A 100X is a stretch, but whats a little stretching between friends. :)
Updated:
http://www.hydrogen.energy.gov/pdfs/progress04/ivi4_carlson.pdf
Gives projected cost of $4000/kW for fuel cells in 2010. This gives a ratio of 461.
Tom,
I might be the only one who read your link, but I don't see anything stating $4000/kWh for Fuel Cells in 2010, if I am wrong, please point it out to me. The chart and table on page 5 is talking about storage tanks and not the cost of the fuel cell itself. And it's quoting the DOE target a $4/kWh for the storage tank in 2010. Don't seen anything that states that the chart is listed in thousands of dollars. This chart is also only probabilities and not reality.
Check out :
http://www.ovonic-hydrogen.com/home/home.htm
Watch the video:
http://www.ovonic-hydrogen.com/video/h2_car/h2_car_100k.asf
They are targeting 250m+ per fill at a cost of less than $3/kg, this year . I do not know all the maths to do the conversions, but depending on the efficiency of the fuel cell, the energy density of hydrogen versus the energy density of lithium batteries, the hydrogen tank is the better way to go if you can compress it enough, as these guys have done.
Also, besides this flawed reading of that document, the argument in the first part of your post is completely flawed. You are comparing the cost of the fuel cell, versus the cost of the ICE. These are not the same thing, apples and oranges comparison. The fuel cell does not directly convert the hydrogen to motion, but powers and electric motor as does the battery.
The cost of a battery that can go 250 mi per charge is somewhere in the range of $30,000 versus your fuel cell, which is simply a converter. While using electricity or other means to produce hydrogen may be more efficient in theory, the need to store that much energy in a form compact enough and lite enough to be used in mobile applications is expensive in both technologies. However, from what I can tell in my readings on the internet, the cost of hydrogen storage is coming down more quickly that the storage of electricity. I also believe that using the energy stored in chemical bonds formed by naturally occurring elements such as hydrogen and petroleum may be less efficient over all than creating batteries to store and harness electricity directly, there are many benefits that will not be outweighed by the efficiencies until the cost of electric storage comes down and "recharging" becomes as quick and simple as refueling a gas tank or compressing a gas.
Until that time, versus other sources of energy, I believe pursuing hydrogen has many benefits. Done correctly using solar and electrolysis, the energy infrastructure can become decentralized and robust. Then when the storage of electricity catches up to those of traditional storage, we can make an easy transition.
To break it down and sum it up, the technology for using hydrogen to fuel a vehicle in a manner consistent with what we are used to today is already available at a cost that is not currently unreasonable and is in a downward spiral. However, the technology for using electricity directly in a manner that is also consistent is still down the road a piece in terms of cost. So if we build out a decentralized infrastructure for capturing electricity from renewable resources and use that to generate our hydrogen, we will be ready for the transition to pure electric when and if that becomes cost effective in the future.
Tom,
So you are saying a hydrogen fuel tank that holds the equivalent energy of the Volt's battery pack (16 kWh) would only cost $4/kWh * 16 = $64
BigRedFed, What are you saying?
BigRedFred & Jason
It is NEVER more efficient to convert electricity to hydrogen and back, than simply storing electricity in a battery, NEVER.
The Second Law of Thermodynamics is always right. I used to be a big supporter of Hydrogen until I did the costings, and it just does not work in an automotive environment.
In the home, a fuel cell works well, running off natural gas to make heat & power. I would also point out that peak gas is also coming, in the USA anyway, so cheap hydrogen is just not possible.
NZDavid,
No one is disputing that fact, but hydrogen has other attributes that make it valuable is certain applications:
1) rapid refill - you can recharge your fuel tank in 5 - 15 minutes with hydrogen, while BEV's require a min of 3 - 4 hours in the best cases, and 6 - 8 for the typical vehicle. Military applications will demand rapid refill, while automotive customers will prefer it - paying a premium
2) specific energy - energy storage in hydrogen is much lighter than batteries, making it an optimal aviation fuel
Nanoptek has created a solar hydrogen generator that skips the electrolysis step and uses sunlight to directly generate hydrogen very efficiently.
http://www.nanoptek.com/
NZDavid,
I really used to push for hydrogen as the best solution there is. But with the new development in batteries, I scaled back on that recommendation.
I used to argue that for machines or equipments that cannot be connected to electric sources, they needed fuel, and the best fuel is hydrogen. The direct solar hydrogen generation to storage, then to machinery would have been several times more efficient than from solar to biofuel (even using algae that is several times more efficient than terrestrial plants), until there were ideal batteries.
Still by and large, I agree that hydrogen are still useful in many cases and even in some large applications such as military, aviation, and even space exploration. But for now, electric batteries would seem to be geared for success, with almost certain probability. But I do love that people still work on Fuel Cells and its further improvements, like bringing the total costs down. Solving our problem should be multiple approaches and try to perfect its approach. It could provide diversity and stability in ever changing needs, so one technology may be appropriate in another changing situation compared to the current ones.
I used to keep track of several companies in solar hydrogen production using solar concentration and catalysts. The best efficiency that I have seen is around 46%, from the sun's energy into the energy of hydrogen. Compared to the best terrestrial plants in the world, from the sun's energy unto the energy of the biofuel, the best would be around 1% overall efficiency. And there is still room for improvement in the field of solar hydrogen. For example, using cheaper electrodes that can survive high temperature and pressure and the splitting of water is triggered by electrolysis that require only minimal electric current. It has been patented and I cannot find the patent number or reference currently. But suffice it to say that they do have many exciting research development in this field, but it is really too bad that the Australian companies and the Canadians have advanced much more than the US companies in the field of solar hydrogen. I did not continue to keep track about solar hydrogen when I got excited about the new batteries, Volt and Aptera. I will get back to it again at the appropriate time.
One of those companies, IIRC, is Shec-Labs, aside from Nanoptek. I wondered what happened to Shec-Labs. They used to have a demo of solar hydrogen in Southern California. Then there were several turnover of CEO and board of directors, and I was suspecting some third party investors of Oil companies, and pfftt... they're off the limelight.
But with many exciting companies now such as Aptera Motors and Sapphire Energy, whose fundings are seemingly clean from the owners of oil, I think there is a big chance to take off of oil. I'm still worried that GM has Oil companies as the major investors thru convoluted relationships with other holding companies and I really hope I am wrong on this. I don't want them to shelve the Volt by influencing the direction of GM right now. We believe that we have the best direction right now, starting with the Volt.
Texas is right
Electric is the future. All this talk of hydrogen is a lot of hot air. I was a beliver in hydrogen for awhile, but when you research it, you find it is just not viable. The cost of transportation, splitting, storage, infrastructure, and so on is not needed. When you can simply plug a car in, you got every other tech beat.
Regarding the batteries this Jason guy mentions. Better check on eEstor. They have made a battery that takes all of 3 mins to charge, and it will be coupled with a car from ZENN motors. It will be a major challenge to Volt and other electric vechiles. Of course a battery that can be charged in 3 mins takes a lot of amps, and household electric services will have to be upgraded.
The car that TaTa motors in India is coming out with beats hydrogen also. It runs on compressed air, and will be avaible even sooner than the Volt.
The future looks bright with these options coming on from a variety of sources. Will be in line to buy first day.
Your information is out of date, which is exactly why all tech should be allowed to move forward.
EEstor is developing a capacitor, not a battery.
ZPM has licensed MDI's (Tata) tech for an Air Car in the US.
Enginair has a rotary air motor, which would be good as a range extender.
EEStor is still a dream. Unless they come out of stealth mode and into the open and show scientific proof or white paper or technical paper in peer reviewed journals, then they're still unrealized dream. I'm hoping that what they've achieved is real and is commercially viable. It would be the next revolution alongside with the battery revolution.
room for everyone. The fuel cell right now does potentially have a place assuming two things. Price can be lowered (which is happening) and batteries don't advance to the point of being able to be charged up in minutes.
The ONLY advantage a fuel cell has over a BEV that I see is unlimited range without long charging stops.
Cost of a fuel cell is unlikely to ever drop as low as an E-Flex vehicle.
So the way I see it Fuel Cell vehicles will have a niche. That niche might would be very high milage vehicles. Why? Because it makes sense for me and you to drive the first forty miles on battery and then anything over that on ever increasingly expensive gasoline because we just won't need to drive long distances very often.
A 18 wheel truck driver on the other hand will routinely make trips of 200+ miles or more... even cross country trips regularly. 40 miles of electric to them is a drop in the bucket.
So in my eyes the extra cost of the fuel cell could be recouped by truck drivers. But for low mileage people (most everyone) the price of the fuel cell would never come close to being recouped.
I also don't see the cost of electricity that is generated from a fuel cell as ever getting as cheap as electricity from you house. Think about it... if a fuel cell can be made that can produce electricity cheaper than you get from a wall outlet what is to keep the electric companies from also using this technology to produce their electricity too.
Please tell us how heavy the car you are proposing is and how far this range extender is supposed to go. I will then calculate how big your trailer needs to be to hold the compressed air tanks. ;)
I know I keep bringing it up but you keep saying compressed air will work as a range extender. The other thread already proved it's not viable.
Two steps forward, one <==
BigRedFed and Texas,
I tried various searches to get a fuel cell cost per KW. The only thing I could find were cost estimates by Carlson. I obviously made a big mess out of reading it.
Guys. Thanks for your correction. Your right. That particular document has nothing about total fuel cell cost. I'm mystified at how I got $4000! There is another report by the same author at http://www.nrel.gov/hydrogen/pdfs/39104.pdf. On page 28 he gives the cost of a 2004 50 kW automotive fuel cell system at $176/kW. If you can a better number, give a shout.
This works out to be 20X cost factor, per KW, of fuel cell over ICE. It's interesting, but this turns out to be almost equal to the factor of 21X I got under "Rough Numbers: ", just by pulling numbers out of the air!
BigRedFed
"apples and oranges comparison"
I find it to be an interesting comparison. Just another yardstick to compare technologies and another little fact to be tucked into my storehouse of EV knowledge.
I am saying that the document is simply quoting a DOE target. So yes, the DOE targets, according to the document, hydrogen storage equivalent to the Volt battery pack at approx $64. According to the document though, they are predicting that it will be about four to five times that expensive, or around $250 - $320. Still cheaper than a volt battery to store the equivalent amount of energy.
BigRedFed
Tom,
20X Cost factor, per kW, that's why I think we should look also at H2 ICEs. Ford already has the engine and so does BMW.
Old articles: http://media.ford.com/newsroom/feature_display.cfm?release=18794
http://www.electricdrive.org/index.php?tg=articles&idx=Print&topics=64&article=1206
To me, the only real way to move to all electric is to transition, as I stated above, from gasoline to hydrogen to ? to full electric, depending on the advancements in battery tech.
I think GM has a good stop gap with the Volt, but Ford and Honda may have the jump on the Hydrogen front, but GM is still my pick because they are not far behind on Hydrogen.
Tom,
The two configs which will eventually win out will be PFCV and rapid recharge BEV. Compressed air and ethanol will end up being the low cost vehicles for the poor, while PFCV and rapid recharge BEV will be the high performance vehicles for the wealthy.
Is that just the cost of the tank or all of the systems needed:
Do realize those tanks are over 4 inches thick of extremely expensive carbon fiber, have limited life and will probably need to be water tested every 5 years? That's what the DOD currently requires for high pressure tanks that travel on the road. Only $64 for 16 kWh? Bull$%^&. YOU ARE DREAMING... PLEASE WAKE UP.
It must kill you to see all the pieces coming together for hydrogen. Small, high pressure tanks, cheap fuel cell stacks, EV systems and components cost reduced in REEV's, so that fuel cells and hydrogen tanks can swap right in later.
I like Quantum's portable hydrogen fuel station:
Link
You or I must be viewing an altered state of reality. I just can't see Hydrogen as a "transition" to anything else on the horizon, including BEV. First of all, I recall anouncements for 120 mile BEV's and they are at "reasonable" pricing. These are first generation vehicles. I don't see much of leap for them to be 200+ mile vehicles in the 2nd generation and 250+ in third generation. I see this from the recent past battery development progression (especially Li) and the current frenzy of developments. Secondly, who wants to invest the trillions of dollars in hydrogen infrastructure as an interim industry?
What am I missing about EREV development? 40 miles AER developed today reduces gasoline usage by 80-88%. I see developments of 2nd generation EREV's reducing usage to 5-10% of todays cars. Please explain why we should be bothering with Hydrogen for cars.
I'm not saying it is a bad idea to research and develop hydrogen for all applications. It already has some today and there will be more tomorrow. We should encourage development of the technology. It may end up being a home energy storage solution, an airplane energy carrier solution, a trucking energy carrier solution, and even a utility grade energy storage solution. I just do not see any way that it can be a practical solution for light duty vehicles in this country unless other forms of combustion are outright banned. Countries such as Iceland that have an overabundance of energy may move to hydrogen use in cars but they will be wasting a LOT of their energy with this choice.
41 - 60 of 87 Posts
