Wow, that is such an obvious solution to the compression issue - 90% sounds good enough to me - forget heavy batteries, here comes lighter than air hydrogen!
Wow, that is such an obvious solution to the compression issue - 90% sounds good enough to me - forget heavy batteries, here comes lighter than air hydrogen!There is a very efficient process that removes this step, and it is very simple. Do the electrolysis under very high water pressure. The separated gasses are already compressed. Compressed gasses stores energy, aside from the energy of hydrogen itself. The compressed gasses can also be utilized just like in cars running on compresed gas, but after the decompression step, you can use the gasses for the fuel cells. The Dutch were the first to pioneer the approach of doing electrolysis under high pressure and temperature... The overall efficiency if you can recapture the energy of the compressed gasses plus the energy value of hydrogen is nearing 90%, but still not as good as some energy recharged unto batteries.
... and those who continue to follow the old cookbook engineering paradigm will fall to the two groups who exploit their weakness:I don't believe in throwing dice to make decisions or evaluations. The universe we live in has certain constraints. The laws of thermodynamics are irrevocable. Water runs downhill. The mere fact that life exists dictates the fundamental constants and balances of the universe. One can rely on the laws of probabiliities: Ocam's razor, "Murphy's Law". Physical processes have certain limits and implications. Designing a product is a process of making a series of best judgements and cost implications out of a sea of almost infinite possibilities. Design is the process of making these specifications explicit. Yes there will be new discoveries, in some case unexpected, but they will be made by those who have a deep understanding of their work.
The visionaries are still constrained by many things. Cost, physics, to name just two.... and those who continue to follow the old cookbook engineering paradigm will fall to the two groups who exploit their weakness:
1) visionaries, who can see beyond the "common knowledge"
2) genetic algorithms, which will pursue all options, allowing the solutions that consumers prefer to evolve
... and yet, when we allow only the "knowledgeable" to select our only paths, we end up spending close to $1 trillion to develop the Tokamak, with no results ...... and those who continue to follow the old cookbook engineering paradigm will fall to the two groups who exploit their weakness:
QUOTE]
Genetic algorithms are very useful in nature. There are, for example, gazillions of insects in the world; permitting RANDOM mutation and selection to change the population is therefore possible, the cost of a single insect with a bad or useless outcome is insignificant. You could implement a genetic algorithm in a computer, where the cost of each calculation is very low (because memory and computes are very, very cheap).
Government and industry can't work like that with energy projects. The cost of a blind alley is significant and we avoid it by focussing on the likely and finding ways to rule out the unlikely.
If a technology requires high capital cost, several significant breakthroughs or even just one "breakthrough" that's really a stop at the wall of physics, it's best to consider the alternatives.
... so we should allow all paths to proceed without interference, as each will innovate to increase their strengths and mitigate their weaknesses. You only have to look at the automotive industry in general to see how multiple solutions, which optimize different aspects, find their niche markets.Jason,
What you say is true, but this is only a part of the picture. Let me give you a quote and mantra from the leader of one of the most innovative and visionary companies, ever, Andy Grove, CEO, president and chairman of Intel, "The devil is in the details." Yes, vision will lead to new paradigms and breakthroughs. But, the vision will be unfulfilled, and litter the dustbin of history, if it doesn’t comply with the inexorable contraints of reality. The details that that will make or break it.
As soon as I'm not busy, I'll try to search those papers. Many great technological breakthroughs are not in the market today doesn't mean they are not great. Proper timing and public demand has a lot to do with the success of building a better mousetrap. Another big factor is the patent. If the patent prices are exhorbitant, then the innovation may not move further. And if it indeed was marketed by others, the patent troll attorneys will have a field day. Still others, some oil companies, using some third party representations, are behind the killing of the innovations. They buy these patents and shelve them. And if it was done by another, there will be hell to pay. I have seen many innovations that were killed. A better mouse trap is not a guarantee that they will be sold or adopted.References please. Let me check things out and see why they are not being used today.
Where is your "evidence of fact" that fuel cells cost $150,000? Honda and Toyota are moving forward with their FCV's, so I doubt fuel cells are anywhere near that expensive.The efficiency in using PV to directly charge batteries is 2 to 3 times greater than any sunlight to hydrogen process. Once you get hydrogen, you have to use electricity to compress it. Then you put it into a fuel cells which are very expensive, typically 100 times more expensive per kW output than conventional internal combustion engines. The fuel cell then has an efficiency of 60% and only works above -20F (i.e. southern states). The losses in generating and using (high pressure) hydrogen make it an expensive alternative to the grid/16 kWhr battery. Those are the facts.
Solar energy combined with hydrogen is better than electric from the grid to power an erev.
