1 - 5 of 5 Posts
Not sure of that designation but I suspect they are asking for 15NM average, plus or minus 2NM, therefore any range between 13-17NM.
Heck, it's only a battery terminal, I would not get loose any sleep over it....tighten it till its tight enough ;-)
It is not a mechanical moving joint after all...
Banned
That bulletin adds this change:
Version 4
Modified Oct. 17, 2016 – Changed torque specifications to 15 Nm or 133 in/lb from D15+/ 2 NM S13-17 NM.
Yes, that's in/ibs (inch-pounds)
Its a battery terminal, just get it nice and snug.
What socket's are needed-?
The only you-tube video I found has him saying he needed another socket that he did not have.
Plus he was INSIDE the car doing it.
The bulletin you have listed is not for the battery terminals. Its for the under hood fuse box, the nuts are 8mm and 10mm in size. Its unlikely causing a issue with the shifter not going in to park. There has been issues with the shifter itself causing this problem. There is a small switch in the shifter that starts to make a poor contact. The repair is to replace the shifter, this would be covered under the bumper to bumper warranty.
#16-NA-060: Difficulty Shifting Out of Park or into Park - (Mar 6, 2018)
1 - 5 of 5 Posts
