So long, and thanks for all the fish.The answer is: 42
I can tell you that the engineers at GM spend countless hours trying to find just the right balance of range / ride quality / wet & dry traction / load capacity / tread life. The final determination is shown on the tire placard on the driver side door pillar. I don't see a reason to doubt their efforts to find the best balance.Took delivery of my '17 and the tires were at 37 psi... max on the tire is listed at 44. Has anyone played with the psi to find the best balance of max range / ride quality?
It is only good for the tires that came with the car and if you replace with the exact same tire.I can tell you that the engineers at GM spend countless hours trying to find just the right balance of range / ride quality / wet & dry traction / load capacity / tread life. The final determination is shown on the tire placard on the driver side door pillar. I don't see a reason to doubt their efforts to find the best balance.
VIN # B0985
I do this ^^. I run as close to the door jamb recommendation as possible. With the 20" low profile on ELR, they get pretty harsh above 38psi or so. Road noise increases as well.I can tell you that the engineers at GM spend countless hours trying to find just the right balance of range / ride quality / wet & dry traction / load capacity / tread life. The final determination is shown on the tire placard on the driver side door pillar. I don't see a reason to doubt their efforts to find the best balance.
VIN # B0985
I used to think think that would be the case, but I have come to doubt it. For instance, a lot of Volt owners who ran the recommended pressure got uneven tire wear consistent with low pressure. It also does not explain why the recommendation changed from 36 to 38 for the 2012 model year despite no change in vehicle weight or tire size. In fact, I have had excessive shoulder tread wear on just about every car I have owned, despite keeping the tire pressure well maintained. Maybe the manufacturers are good at balancing those competing priorities, but their balance is different from one I would choose. In any case, I now consider the placard value to be an absolute minimum that you should never let the cold pressure fall below, and ideally it should be a good 10% above it. Even more for the Volt, based on my experience. I use 44 cold on my Gen 1.I can tell you that the engineers at GM spend countless hours trying to find just the right balance of range / ride quality / wet & dry traction / load capacity / tread life. The final determination is shown on the tire placard on the driver side door pillar. I don't see a reason to doubt their efforts to find the best balance.
VIN # B0985
