Do whatever your owners manual suggests.My 2013 Volt hit 50k miles this week. Is there anything in particular that I should do or scheduled maintenance needed at that point?
There are no problems or errors present.
I just had mine in for the tire swap and 5 year service (only 64,000 km.). The only recommended service was to replace that cabin air filter, which was odd because I don't have one. I did get an alignment done, which I needed, and when I got home I pumped up the tires to 38 psi. It seems the dealer compressor only goes to 30, because despite putting 38 on every service order, that's all I get.You should probably replace the cabin air filter if you haven't already. I can't think of much else.
I bought a "universal" furnace filter w/charcoal very much like this oneThanks for the tips.
I do not know if the 12v battery is original or not. I purchased this car used about six months ago with 36K miles on it. I'll see if I can figure out its real age.
I've been thinking about replacing the cabin air filter anyway because SWMBO complains about 'strange odors' when the AC first fires up.
Alignment was checked to be within spec. when I replaced the tires in January.
I'm still just loving this car.
Your car will only have a cabin air filter if you or the the previous owner installed one. Check behind the glove compartment to see if there actually is one in the slot for it. I don't know how much this would help with AC odours, but allergy season is upon us.Thanks for the tips.
Reading the Fine Manual is a great place to start, but it rarely covers the insight that is gained through the tribal knowledge and experience gained by a large group of owners. That's the beauty of this web forum. There is much more to be learned here than just what is covered in the owners manual.Someone else just posted same question on a Volt with 56k miles. Does anyone RTFM anymore?
No. Next question please.Does anyone RTFM anymore?
I've tried the search function a few times, not very helpfulNo. Next question please.
Does anyone use the forum search function anymore?
No.
That is a requirement. And it is fully described in the manual. It says specifically not to use light beer or imports.Celebrate 50,000-miles with a beer!
Sometimes it's not very helpful, no. That's when you break into your Google-fu. Start the search with "gm-volt" and add.I've tried the search function a few times, not very helpful![]()
If you notice, mister dave says RTFM in every one of hist forum posts, it's in his signature.I never fail to be astounded at the people who get upset and scream RTFM. Look folks if you don't want to answer the question then you can always remain silent.. it's easier on everyone's blood pressure.
