Most camp sites have a breaker box per camper space. Inside you will likely find some combination of the following:Late to the party as usual but...
Using this post and others linked to, we're planning on getting one of these: http://www.autoanything.com/truck-tents/77A2945A3066850.aspx as referenced earlier and doing what will likely last two months of travel next year. We will also have the Volt prepared for sleeping in bad weather as well. (I've had many a thunderstorm mess up a nice trip in the Adirondacks.) I'm sure if we plan properly we can hit many points of interest from select campgrounds doing daily out and back trips. I'd like to be able to bring my L2 charger with me and "fill up" quicker in order to get in a sight seeing day, clean up while charging up, and perhaps get something better to eat than a can of beans on a Bunsen burner! (My wife enjoys Blazing Saddles but not so much in the confines of the car) What I'm looking to learn now is what is the "normal" or most widely seen plug/receptacle I'd need to be geared up for? I know I saw a post referencing a kit or something with adapters but I can't seem to find it. I installed my LCS-25 hardwired but have a nice disconnect as well as breaker and I could be ready to go in less than ten minutes safely. Of course it may be moot if we're not able to park with the big boys to use that level of charge and are relegated to a tent site with 110v.
Thanks in advance for any help on the receptacle thing.
Example 1: Standard 120V 5-15 plug (the plug type your OEM EVSE uses)
Example 2: RV 120V 30 Amp - You can buy an adapter at Walmart for $2.50.
Example 3: NEMA 14-50 240V 50 Amp.
I made an NEMA 14-50 to NEMA 6-20 adapter I use with my Turbo Cord. There are plenty for sale as well.
When camping without 240V, I use the 30 Amp adapter (when available) for the EVSE and then use the regular plugs for other stuff. Not sure if it makes a difference, but I feel better using the 30 amp plug on a dedicated circuit. Just remember to reset the car to charge at the higher rate since you can do so without worry.
Occasionally, you might camp at a "tent" space that may have shared 120V between several sites. In that case, consider charging at the lower rate unless you are sure nobody else is using the circuit.
