Preconditioning on DCFC might be very easy and low impact on the Bolt EV.
We'll want to verify this further, but so far, if the amount of power the charger is able to provide exceeds the power the Bolt EV can accept, it looks like you can redirect that excess toward the climate control settings. Under these conditions, the climate control draw was about 6 kW, and turning it on after the charge rate had throttled down had no affect on the Bolt EV's charging rate.
If true, this means that Bolt EV owners in colder climates can use the excess power from fast charging stations to precondition their Bolt EVs before they leave and without affecting the total charge time.
