Gotta love the little Spark EV...
Funny you brought up the i3. I have read that the Spark EV is as fast as the i3 in 0-60 and faster than the i3REX. Same EV range too.... the spark doesn't even come close to the tesla... But I guess you get 1/4th the car at 1/4th the price.... I don't think the i3 quite cuts it. It's more like 1/3 of the tesla at 1/2 the price.
The Spark EV is 1/2 of the Model S because it can seat four.After just visiting the tesla showroom yesterday in Indianapolis, believe me, the spark doesn't even come close to the tesla... But I guess you get 1/4th the car at 1/4th the price. That said, I think I'm more interested in 1/2 the car at 1/2 the price, though I don't think the i3 quite cuts it. It's more like 1/3 of the tesla at 1/2 the price.
+1. You've said it all. Even the Tesla DC chargers are pathetically slow when compared to a gas pump. 320 kWh/minute versus "up to" 2 kWh/minute. Sad but true.We have a Volt and a Leaf. We've done the fast-charging in our Leaf a few times. It is amazing each time we do it. But here's the honest truth. These days, if we are going out somewhere far enough away that would require a fast charge we'll generally just leave the Leaf at home and take the Volt. While the fast-charge is certainly a game changer within the BEV segment as it allows your BEV to be significantly more versatile, it is still no substitute for an ICE range extender. And being how rarely we run the ICE in the Volt (about once a month) it probably needs to run anyway otherwise I'd be getting that annoying engine maintenance mode.
While the advantage still easily goes to gas, 320kWh per minute is slightly misleading. Yes, that's the gasoline going into the tank, but only 20% of that energy gets converted to mechanical energy in a car, in even the most efficient of engines.+1. You've said it all. Even the Tesla DC chargers are pathetically slow when compared to a gas pump. 320 kWh/minute versus "up to" 2 kWh/minute. Sad but true.
New Prius has 40% thermal efficiency, which isn't too bad. Also, in the winter you can recover some of that 60-80% waste to use as heat. However, point is still the same. Any pump-able fuel has battery charging beat for "fill" up time.While the advantage still easily goes to gas, 320kWh per minute is slightly misleading. Yes, that's the gasoline going into the tank, but only 20% of that energy gets converted to mechanical energy in a car, in even the most efficient of engines.
So it's really 64kWh/minute versus 2kWh/minute, though still a good point DonC![]()
This is not good to hear. Was there a pop up msg saying 'reduced power due to temp', or any such thing?....I had my Spark EV charging at a location on L2 over the weekend. It was basically baking in the hot sun for about 1.5 hours. The performance after that was not good....
Should I have preconditioned it or run it longer while plugged in?
I just recently heard a podcast (Bill Nye?) talking about the ICE having 28% thermal efficiency as the limit due to the 'X? law of thermal dynamics'.New Prius has 40% thermal efficiency, which isn't too bad...
Most locales won't let you have a gas pump at your house. So long as it's charged by morning, I don't really care how long it takes. Road trips are another matter of course, but that's < 5% of my miles.New Prius has 40% thermal efficiency, which isn't too bad. Also, in the winter you can recover some of that 60-80% waste to use as heat. However, point is still the same. Any pump-able fuel has battery charging beat for "fill" up time.
I'm glad that someone else noticed that the Volt manual recommends that you stay plugged into an EVSE whenever possible.This is not good to hear. Was there a pop up msg saying 'reduced power due to temp', or any such thing?
It was my understanding that when plugged into any EVSE, even an [email protected] stock unit, that the battery pack TMS is supposed to take care of battery temperature.
I can see if it was outside at the Tucson airport for a week in the summer without being plugged in the system might limit power from the hot battery until TMS can cool it. I would hope it gives a msg when this is happening.
But if the outside temp is not at extremes another line of thought says:.....recommends that you stay plugged into an EVSE whenever possible.
Don't top off a leaf. I wouldn't worry about the volt. When it shows 100% on he dial, it's really much less. Not sure what the spark does.But if the outside temp is not at extremes another line of thought says:
Li-ion batteries have the longest shelf life if they are stored around 40% SOC.
With my normal routine I can strive for this and never top up the battery pack.
