1 - 5 of 5 Posts
I picked up my 2017 Premier Volt 1 week ago, and I love it. Everything was fine until I adjusted the drivers seat height, then a rubbing(?) noise started coming from the left side of the drivers seat, going over every moderate bump, or when I shift my weight in the seat. I tried readjusting the seat height, but it won't go away. It can wait until I go to the dealer for something else, but it is annoying. Anyone else have this?
I just begun to experience random creaks and clicks from the drivers seat of my 17 Premiere (2600 miles) as I accelerate/decelerate and my weight shifts (I'm 190 lbs). I hadn't adjusted the seat prior to the issue. I tried moving the seat in its track but the creaks/clicks are still present. Anyone else experience this?
I am also hearing clicks/creaks that appear to be coming from the driver's seat in my 17 LT. This started a couple weeks ago at about 10K miles. It typically happens when initially accelerating, so at first I thought it might be the accelerator linkage, but the noise seems to subside for a while if I make a seat height adjustment. With the car being so quiet otherwise, it is hard to ignore.
My 2017 started this creaking noise from the left side of the seat at about 40,000 miles. At first I thought it was something in the door pocket, but quickly observed it is the seat. I have narrowed it down to the seat back hinge area on the left side. I removed the screws from a plastic trim piece & it is better. I also wedged some dense foam material between the plastic & the seat covering. That helped some more, but the sound still happens occasionally.
1 - 5 of 5 Posts
