I would appreciate some advice / experience with a strange problem that I'm having with the center entertainment / navigation / display unit in my MY 2013 Volt. The car has navigation and Bose sound.
Everything had been working fine until 2 weeks ago. Now the central unit responds very slowly to input from the touch screen and knobs (at least volume, and power button on center stack, also steering wheel entertainment controls). There is a delay between 1 and 5 or more seconds in responding to input from these controls - a big lag in changing volume, powering off the unit, and I think switching radio stations. There is nothing plugged into USB and I don't think any phones are paired. The backup camera comes on OK but takes a about 5 seconds (variable) to turn off after switching to D or L. The audio takes a similar amount of time to turn on or off after pressing the power button.
Bluetooth also isn't working right: I cannot delete a paired phone or pair a new one. The unit will also not recognize or play songs from a USB stick that has worked before when I insert it.
The problem persists across car startup / shutdown cycles. I also disconnected the 12 V battery for 30+ minutes with no effect. The problem is always there, but the amount of delay varies for about 1 second to so long it seems unresponsive (10+ seconds). The center stack climate controls (I tried fan, defrost) respond normally (quickly).
I'd appreciate any comments on similar experiences, more diagnostic suggestions, or thoughts on whether any firmware updates or other actions might be effective. Thanks in advance for any feedback.
