Are you confusing this with the problem of the steering tending to stick in the center point of the range while driving?I received a letter from GM Canada telling that this problem has been recognised by GM and will be repaired even after the warranty. But this could be different in the USA... I guess a call to GM could tell if this problem is covered or not in the USA. I didn't keep the letter since I've upgraded to a Gen2 model few months later...
My bad, you're right, this isn't the same problem at all...Are you confusing this with the problem of the steering tending to stick in the center point of the range while driving?
